What's the best way to plug in a USB DAC?
ThatM1key
USA
I've got a some what simple question, what would be the best way to plug in a USB DAC? My "new" motherboard comes with only USB3.0 ports on the back and I heard if you plug a USB DAC (which is USB 2.0) into a USB 3.0 port on the back, it increases latency. I also heard if you use the USB internal headers (regardless of USB spec) on the motherboard or use a USB PCIE card (regardless of USB spec also), then they'll increases latency too.
Don't know.
Try one of these softwares and use it in each type of port and see what results you get.
Ideally, get a Febsmart 2 port pcie card for 15 bucks. Put it in a slot that isn't shared with your SATA controllers (disable any not being used). Your manual will show if any interrupts are shared with slots. Running NVME drives in X4 mode needs certain ones too. Don't plug anything but the DAC into it for smooth sailing.
Internally a USB 3 port is both 3.0 and 2.0 in parallel. Both need to be present for backward compatibility, as 3.0 added a second independent set of data pins. Just plug the thing in and don't worry about it unless you're actually having problems.
Where did you hear it and how many times?
Wonder if this is true.
If it does, so what?
I'm not talking about small latency, I'm talking about latency that's high enough to be noticeable.
You sure have heard a lot of bullshit.
I'm still learning in this "audiophile" world. After all, I used to be a hard believer for tubes until I realized what they did to the sound.
First things first, If you are using Windows then you'd have to check the DPC Latency as mentioned by Blumlein88. If you're not on Windows, then I wouldn't really worry about it.
Audio latency and DPC latency are two different things. Audio latency is defined by the amount of buffers in the signal chain, deferred procedure call latency is the delay between acknowledging the IRQ reception to the HW with the very fast first part of the IRQ handler and actually processing the data in the deferred second part of the IRQ handler - nicely explained e.g. in https://stackoverflow.com/a/59005311 Large DPC latency can lead to data buffer over/underflows.
Audio latency is configured by the audio client/OS stack, larger means safer. Using low audio latency requires low DPC latencies of the OS to avoid dropouts. Even a super fast OS can run large audio latency if the audio client requests it.
If you need USB 2.0 and 3.0 will not suffice; most, if not all modern boards have a USB 2.0 header which you can buy a USB 2.0 bracket and have native 2.0 support. However, USB 3.0 is nothing to be feared as its specification and protocol have enhanced audio capabilities for devices that support USB 3.0 and up.
All you need is this from Amazon: https://www.amazon.com/JacobsParts-Panel-Bracket-Motherboard-Header/dp/B00LV1ODSW
10+ years ago 1394 was preferred over USB for audio and I wish it still was. However, USB 3.0+ can finally match the capabilities of Firewire in it's audio stack . So 3.0 is the new win.
I think this thread should just be deleted.
I found it using google. Someone else searching the web might find it useful too.
Eh. It's pretty hard to find a bad port for a DAC. The only reason to care about which port is using it, is priority and data flow. If you ever downloaded anything heavy using a USB ethernet adapter, you would experience more stutter due to the CPU focusing on the i/o data and the most likely shared port. (Personal Experience)
The answers are: Use a cpu-connected USB port (Not chipset-connected), Nothing running in the background, Light fresh OS and a fast enough CPU.
Is this serious? Plugging in a random usb port won't affect your listening, right?
