1st and most important will the Built in DAC of the USB to AUX degrade the sound from the Fosi Audio DS1 DAC ?
The brand I`m looking over uses the KT0210 dac chip not sure if it`s actually designed for audio applications or some other kind of LAB digital to analog conversion... ?
My purpose for the application is using my Galaxy A52 usb c to DS1 dac then aux / USB cord plugged into my 2023 Mazda 3 with the Bose sound system.
Also assuming it`s a 2 way directional cord and not specifically designed for usb to aux....
On a side note Android Auto has opened up it`s user joy by now allowing more apps, I used the USB Player Pro app from the A 52 on it`s own plugged into the Mazda usb and it deaf-inatly made a Large difference & loud and still clear. So naturally I want to try my DS1 DAC !!!!!!!!!!
Suggest using a Flac file of Metallica: and justice for all song it comes alive and now enjoyable the guitar is lite up and separated if your into comparing before and after you will notice it immediately that song is very difficult to find a proper setup to make it enjoyable and an even better setup to hear it as Metallica intended you to hear it !
I`m not indorsing this or insinuating anyone purchase this over others only found 2 brands so far giving up the detail about the dac chip used ...
I have other AUX plugs with the TRRS for a mic and they all work with all my normal stereo AUX ports and extension cords I just forget if there was any issues using them for stereo and I`ve just been lucky .?
Thank you for your time it is always much appreciated !
