audio_tony
Are there any cron jobs setup? crontab -l should list any jobs.I thought for some reason to time incidences of the pauzes; oddly it seems to be more or less exactly 30 minutes between instances.....
Kind of stumped as to what is causing this. The RPI4 has an overspecced PSU, is cool due to heatsink case, not running anything except OSMC and playing back FLAC and MP3 and OPUS files which when inspected are all without flaws in their data BUT at seemingly random times, not often mind you, there is a break in playback - total silence for a second or two - and then playback continues. Rewinding the song that had the pause ( occurs anywhere in a given song of any filetype ) yields non interrupted playback to where before there was a pause in playback..
The RPI4 is set to output over USB in digital sp/dif mode with a limit of 192kHz. I have also tried USB Analog ( which resamples anything to 48kHz )
but no difference. The occurances are as frequent.
Stumped and feeling stupid =/
Try installing moOde, to rule out software being the issue.
I would suggest:
1. Get a Western Digital SC QD101 MicroSD Card 64GB WD Purple Surveillance Camera WDD064G1P0C
2. Install Moode on it using Raspberry Pi Imager.
3. Boot from the new card setup DAC in audio, setup UPnP and DLNA. Restart.
Try playing the same files and see if it works.
The playback interruptions described are a known issue with OSMC and Raspberry Pi setups.
Just for diagnosis. Control moOde from your phone using any mpd client (m.a.l.p. for Android is great).I tried Moode recently but found the control over mobile phone excruciatingly laggy.
But an idea to further rule out causes yes.
I'd recommend using USB 2 - not USB 3 - ports if you want to use wifi: redditit now refuses to connect to wifi even though everything is set as it was.
Thank youAs for the async feedback - on linux you can check the stream0 file while playing to see what the async feedback looks like. Very useful for troubleshooting any USB-audio device. E.g. https://www.diyaudio.com/community/threads/linux-and-24-96.384600/post-6981562
