What is the best way to build a 2 (or 2.1) channel stereo system with dsp room correction
abdo123
Well, I’ve been reading some more and learned that bass cancellation/dips (which is the most annoying problem in my room) can’t be decently solved with eq/room correction. So perhaps I should look to fight those dips with two subwoofers in reverse polarity. Anyone experienced in that department? Difficult?
how big is the room? and where do you sit?
AdamG
Enjoy the Music your way…
Moderator
Sorry for asking. I am new to both DSP and (external) DACs. So...how does this exactly work: the 4 outputs go into two DACs...and then you go with the signal from both DACs where? How? What?
I am planning to have Dali Rubicon 2c active speakers with an active Sub and the Dali Soundhub (incl. BluOS NPM-1).
Welcome Aboard @guycalledfrank.
eddantes
That has room correction? How do you know? I look online and I don't see that at all, so just want to confirm...
No room correction. You are correct. I accept the correction, and stand corrected.
Top
