What do floor standers really bring to the table?
BrokenEnglishGuy
A Kef R7 I guess? If so the coaxial tweeter/mid driver (Uni-Q) probably means you don't have too much to worry about I'd have thought?
Is not a problem at all for me, maybe in the future im going to buy a '' GAS LIFT - EXTRA-SHORT(-5 cm) '' for my sit
JWAmerica
because the listening height it fixed?
:cool:
The average couch seat height is 17-18". Listener height will be a factor, but I think most floorstanders have their tweeters around 36" up so they're pretty much where you'd want them to be. Might be an issue for giants sitting in office chairs.
Chromatischism
something must be vibrating for you to feel it
Correct. A wooden subfloor has a resonant frequency in that range. Or at least, in the last couple of places I've lived that has been the case.
In fact I can activate it quite strongly with the Hans Zimmer track 2049 from the Bladerunner 2049 soundtrack.
Ultrasonic
I can throw in a 10Hz sine wave and stop to hear it when putting my fingers in my ears
Are you certain it's not higher frequency distortion that you're hearing?
abdo123
Brussels, Belgium
personaly I never understood that feelling bass thing. you don't feel bass unless it's a havy roommode shaking your floor. I can throw in a 10Hz sine wave and stop to hear it when putting my fingers in my ears
you're not listening to the correct material then. listen to the track below and turn it up a bit.
abdo123
Brussels, Belgium
but probably at 50Hz-ish where my first room mode is.
You must really know your room :oops:
dasdoing
Salvador-Bahia-Brasil
Pdxwayne
My bookshelf currently retails for $7500. The next step up, the smallest floor standers cost $12000 a pair. So, bookshelf plus stands is significantly cheaper.
Add a pair of the top of the line 10" subs from same company, total retail is $11K. Still cheaper.
dasdoing
I suspect that room modes make things vibrate in their respective frequency?
that's why you can't EQ them, only make them a little less anoying.
but if it is felt like someting positive (feeling the bass), it might be something wanted for most. personaly it anoys me cause it only happens at specific frequencies. and my room is heavily treated with a lot of material on the backwall
Chromatischism
here it vibrates around 2:09 (Spotify)...and again it's a relativly high frequency I am feeling
In my case, the vibrations at 2:00 start when the bass roll reaches 25 Hz. It rolls through the walls, floor, everything. The room stops shaking below 15 Hz here.
At 2:09 and beyond, the energy is at 35 and 70 Hz:
That is the bass that you can feel directly.
