What cables do you use in your systems?
Andysu
Someone on Reddit mentioned that @amirm uses $10k worth of cables in his system. Lol.
Don't you use Amazon Basics, Amir?
amazon light-years x infinity grade that only costs less than £50 for light-year lengths is what i use and doesn't cost the cost of the expanding universe just plain common sense .
by the way . i like your cat .
deniall83
Australia
Thanks! I currently have 4.
2 are permanent family members and 2 fosters.
Andysu
i like the cat in middle looks like my cat Bear "rambo" "jitter" .
nice have 4 cats .
i foster a ladies 3 cats few years ago with my 2 cats , 5 weeks till her family found house .
from left to centre to right
Zeus, Simber , Dessla
anyway back to our regular audio cable unless it's cat curled up in circle of audio cable ?
deniall83
Australia
nice have 4 cats .
Oh they're all so cute!
I'm totally OK with this becoming Cat Science Review.
pablolie
bay area, ca
Boli -the audiophile cat aka pocket mountain lion (he's big)- loves to plonk down between the speakers and listen to music :-D
Andysu
lovely Cat you have .
delta76
I am using kabeldirekt wires/banana plugs. they appear to be well made at reasonable prices. wonder if there is better deal in Europe :)
0800 Dub
England
Speaker cable: Sommer Cable 2.5mm² / 13 AWG
Interconnects: Studiospares (made from Sommer cable) & Custom Lynx RCA cables
USB cable: stock
Power cable: stock
sq225917
Interconnects:
Speaker cable:
Coax cable:
USB cable:
Power cable:
I use all of the above.
Interconnects are belden starquad.
Speaker cable is linn lk400.
Coaxbis whatever came in box with kodak pcd850
Usb is 5m long genuine certified usb cable, some German budget brand.
Power cables, whatever iec cables I had lying round.
Total cost about £100 to wire up TT, phono, pre, dac, pc, monoblocks, speakers.
Freeway
gino1961
Hi to Everyone
I have a question about power cables
Are there benefits from using shielded ones? Which?
Where benefits are mostly evident?
At present i am using diy ones made out of flexible extension cord and better than average plugs but nothing expensive
Thanks a lot
Julf
Amsterdam, The Netherlands
Hi to Everyone
Thanks a lot
Only if you have really badly designed gear and use it inside a factory with huge electrical tools.
Shielded power cables are used for gear that *generates* noise, to avoid radiating it elsewhere.
gino1961
PC -> DAC: Generic USB 3.x
DAC -> Sub (line in): Profigold PGA3000
Sub (line out) -> Dynaudio MC15 (active): AudioQuest Chicago (factory terminated; amazed how good it is and considering upgrading to bulk-DIY Mackenzie)
Also considering upgrading speaker power cables from noname PC-grade garbage to THICC 3x2.5 "just normal AC cable" with Chinese fake Oyaide connectors (all that for roughly $20 per one cable). Just because WHY NOT:p
Hi how do you connect the 3 wires to get the plus and minus?
For speaker cables i would try a 4 wires power cord but they are much less common than 3 wires
Sokel
They can come handy if someone wants to connect chassis's together on top of the common ground connection.
You just use the shield test and measure what's better.
(I'm talking about diy ones,not ready made that the shield is tied to ground)
TheBatsEar
Germany
Friend needs new cables, 2x 5m.
Are we ok with copper plated aluminium cable if they are thicker, so the resistance would be the same as if it where a thinner copper cable?
Are they stiffer than copper maybe?
delta76
Hi to Everyone
Thanks a lot
no. only in circumstances that are very unusual for home (and if that is the case, you have much bigger problems to worry about)
SIY
Alfred, NY
I would recommend against it. The DCR is higher unless you go ridiculously thick, and even more seriously, the high mechanical creep of aluminum almost guarantees that the connections will be unreliable over time.
TheBatsEar
Germany
@SIY Cheers, that's all i need to know.
fpitas
Northern Virginia, USA
Interconnects:
Speaker cable:
Coax cable:
USB cable:
Power cable:
Interconnects: Mix of Amazon basics and BJC XLR balanced
Speaker Cable: Monoprice 12AWG twisted pair intended for in-wall use (but it lies on the rug)
Coax: Amazon basics HDMI to the monitor
USB cable: Amazon basics USB B to USB C to control the DX 2006 from the laptop (no audio)
Power cables: Belden, Middle Atlantic and Amazon basics in various lengths so the rack wiring is sane
