So why would AES3 need 100 MHz?The context was AES3.
Well, that's basically the same thing:For Ethernet signals and transceivers, yes. That doesn't mean some other encoding will necessarily work.
The AES/EBU standard does call for shielding. It’s always possible that another cable configuration can work, but do recognize that all digital cables are not interchangeable by design.Maybe.
If you want, you may still use S/FTP cable.
But any Cat5 cable is at least 100MHz certified up to 100m.
So..
1800F is designed for use with balanced cables.Why? Balanced is way less susceptible to induced noise.
What works and what doesn't depends on signal level, receiver sensitivity, and other things. AES3 is robust enough that in practice it works over almost anything. S/PDIF, while using the same encoding and thus bandwidth, probably won't work (reliably) over 100 m of any cable due to the much lower signal level.Well, that's basically the same thing:
you send bits through kind of a serial connection through a balanced line.
If I'm not mistaken, the AES standard is up to 192kHz.
If you imagine 32 bits, you need around 12Mbps for stereo.
You have way more.
And even if that's 768kHz, you have room left.
Actually, on a Cat5 cable, you may easily transport 8 channels at 768kHz 32 bits over 100m, since you have 4 pairs.
It seems like a reasonable number to me. Old 2 channel 44.1x16 SPDIF had content up to almost 15 MHz.So why would AES3 need 100 MHz?
Well, the cable won't change the signal level, receiver sensitivity or other thing, will it ?What works and what doesn't depends on signal level, receiver sensitivity, and other things. AES3 is robust enough that in practice it works over almost anything. S/PDIF, while using the same encoding and thus bandwidth, probably won't work (reliably) over 100 m of any cable due to the much lower signal level.
Of course not.The AES/EBU standard does call for shielding. It’s always possible that another cable configuration can work, but do recognize that all digital cables are not interchangeable by design.
I also use LC-1 for my phono cable, keeping in mind the desired capacitance for my cartridge and phonostage. My current cable config with low capacitance works much better with my MM cartridge than the high capacitance cable I used previously. Since my phono does not have adjustable capacitance, I used a length of cable to provide "optimum" cartridge matching per the Hagerman Labs calculator. I don't swap MM cartridges often, so I was okay with this tradeoff.I recently grabbed a Blue Jeans LC-1 and a World's Best Cable with Canare wire and Neutrik Rean connectors. Hoping to use the LC-1 as my phono cable which worked well for me in the past. Probably going to make my own ground wire as my phono stage has a weird ground lug.
All cables attenuate the signal to some extent. If the attenuation is too strong, the signal strength at the far end will drop below the sensitivity of the receiver.Well, the cable won't change the signal level, receiver sensitivity or other thing, will it ?
Yes (most likely), but not for the reason you said it would.What I said is that, as a cable to transport signal according to AES/EBU standard, a Cat 5 cable will work.
Sure, to some extent, but at reasonable distances it is not really an issue.All cables attenuate the signal to some extent. If the attenuation is too strong, the signal strength at the far end will drop below the sensitivity of the receiver.
It’s the “reasonable” part that can be at question. For long runs, balanced cables would be preferable to unbalanced RCAs if for no other reason than higher nominal signal voltage.Sure, to some extent, but at reasonable distances it is not really an issue.
Insertion loss is part of the Cat5/6/7 certification criteria.If the attenuation is too strong, the signal strength at the far end will drop below the sensitivity of the receiver.
If you are wiring stadiums, fibre is the way to go.It’s the “reasonable” part that can be at question.
Balanced would definitely be preferable, but more for the reasons of common mode noise rejection and avoidance of ground loops than signal voltage. You could easily boost the voltage of an unbalanced connection too.For long runs, balanced cables would be preferable to unbalanced RCAs if for no other reason than higher nominal signal voltage.
Agree that all of those matter, too. The "ease" of boosting an unbalanced connection output also comes with greater complications in many setups.Balanced would definitely be preferable, but more for the reasons of common mode noise rejection and avoidance of ground loops than signal voltage. You could easily boost the voltage of an unbalanced connection too.
Those cables are also specified with 100 Ω characteristic impedance, whereas AES3 wants 110 Ω. That mismatch will cause higher losses than when the same cable is used for Ethernet.Insertion loss is part of the Cat5/6/7 certification criteria.
An impedance mismatch causes reflections rather than losses. Of course some of the power reflected results in less power transmitted, but that 10% difference less than 1 dB of loss...Those cables are also specified with 100 Ω characteristic impedance, whereas AES3 wants 110 Ω. That mismatch will cause higher losses than when the same cable is used for Ethernet.
