- Joined
- Aug 14, 2018
- Messages
- 2,776
- Likes
- 8,162
I believe you. I had a quick look at Schiit website and they don't specify anything above 2V. Next question is it's ability to drive 4kOhm.
Amir’s review of the Freya S here will have the info.
Amir reviewed the Freya S, which is solid state.Amir’s review of the Freya S here will have the info.
I can't speak to the possible technical reason, but I'm not fond of the Hypex buffers that I ordered with my VTV Purifi amplifier.Its not BS. Its an evaluation circuit for designers to use, not for use in final products.
That eval buffer has no input filtering or GBW limiting. Its wide open to external RF or that from DACs. You can find a couple of forum users here that had "digital noises" due to intermodulation with the class d switching signal. They fitted a filter and problem went away.
https://www.audiosciencereview.com/...ith-ncore-amp-apollo-twin-x.11771/post-400198
https://www.audiosciencereview.com/...ltralite-mk4-akm-dac-version.3796/post-400194
My search fu didn't bring anything. Since the personal interest I have for tubes is close to 0 I have to admit that the search was quickHe didn’t also review the Freya+ separately?
I went through exactly the same experience. I bought a VTV Purifi stereo amp with stock Hypex buffers and found the top end to be harsh sounding. I consulted with Warren (of VTV) and updated the buffer to Sparkos SS3602. It smoothed out the harshness and made the sound very enjoyable. I swapped between the buffers a few times and the difference was very noticeable. The downside is that choosing any of VTV custom buffers bumps up the price considerably.To my ear, (sorry, subjective), the amp showed amazing resolution and dynamics, however on loud passages high pitched instruments such as brass, violins, some woodwinds produced a lot of "glare", by which I mean a brightness and harshness that was unnatural. I have ordered VTV's own buffers and selected the Sparkos SS3602 op amps.
YepThanks for sharing, but gather this only applies to the NC family Hypex modules? Do you need to filter MP family amps as well?
To begin, my VTV Purifi looked exactly like Ruggers and I agree with him regarding the construction quality, etc. Likewise I'm no technical guy either, maybe less so.
To my ear, (sorry, subjective), the amp showed amazing resolution and dynamics, however on loud passages high pitched instruments such as brass, violins, some woodwinds produced a lot of "glare", by which I mean a brightness and harshness that was unnatural. I have ordered VTV's own buffers and selected the Sparkos SS3602 op amps. I'll see how those sound by comparison.
My repo chain consisted of FLAC files, mostly 16/44.1; Foobar2000 with mild equalization using the Graphic Equalizer component; Topping D90 DAC; Freya + in 'Passive' mode; VTV Purifi with Hypex buffer; Zaph Audio ZRT speakers.
In the end, I decided that my system was still in flux and I wasn't ready to settle on an amp yet. I returned the amp during the trial period but may end up going back to VTV, perhaps for monoblocks. Warren was a pleasure to work with, always responsive and helpful. When I told him that I decided to return the amp, his response was a simple one-liner, "No problem, just ship it back to this address...".
The electronics appear to be quite different between the Purifi Eval1 board and the Hypex buffer board. I wouldn't expect them to sound the same.Could you name a couple of song where you found this particularly noticeable? I'd like to see if I can reproduce it on my sistem. I also usa a D90, then into Freya S and a Purifi Eval1 based DIY build, so quite similar electronics.
Your comment about harshness in case of the Hypex with orchestral brass and strings is exactly right, IMO. At least I had the exact same impression with Hypex. I have VTV buffers on the way equipped with Sparkos SS3602 op amps; I'll see if that improves the situatlon.The electronics appear to be quite different between the Purifi Eval1 board and the Hypex buffer board. I wouldn't expect them to sound the same.
Purifi Eval1 board (stereo)
Hypex buffer board (mono)
The treble harshness I heard with the Hypex buffers is immediately apparent on recordings with brass and orchestral strings. Here are a couple of examples but the harshness shows up easily in classical recordings.
Just to clarify as I checked with Hypex support. The MP family amps do have RF filtering on the audio inputs as does the NC1200.
NC500 does not have filtering either with or without the buffers on the eval buffer board.
awesome. I think I will pick up one of VTVs 502MP amps and can do an A/B against the Puirifi
