WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
From what I read on the Spotify site I'd need to have something that can stream from wifi to my stereo system, maybe via a small computer out to an AUX input on my preamp. That sounds (no pun intended) like a lot of signal degredation to me. How are you getting Spotify to play on your sound system?
I'm using Amazon Music. The digital stream from my laptop goes to a Topping E30 DAC. The sound is plenty clean. I could stream Spotify too, I just don't.
From what I remember, the best declickers actually un-RIAA the audio or even act before RIAA is applied at all, as apparently the resulting super fast transients are very easy to detect. (The RIAA / inverse RIAA needs to be minimum phase (IIR), Audacity's EQ is FIR based I think and as such not suitable.)
One aspect of note is that vinyl audio tends to be full of high-frequency nastiness that can challenge lesser anti-alias filters. Especially when dealing with consumer-level ADCs (typical stopband rejection ~70 dB) I would definitely recommend running those at 96 kHz, while higher-grade converters should be fine at 48 as well. The designation "consumer-level" includes not only early/mid-2000s consumer soundcards but also e.g. the CS4270 codec found in a number of USB audio interfaces to this date. A CS4272 (or CS5361, CS5381, AK5385A) should be more trustworthy, and ones with top-grade filters (e.g. AK5394A, CS5396, AK5393, AK5383) should be pretty much unfazed even at 44.1.
Are they superior to simply feeding the output from a "normal" preamp with a phono section into a PCIe audio card in my computer and letting Audacity go to town on the captured signal?
I'm retired, convenience is way down on my list of considerations . Thanks for the specifics; I'm gonna pick up my PCIe sound card and magnifying glass and look at the ADC chips. I know it has 5532 op-amps on it, but there's no room for 12AX7s, sooo...
Is it me or the clicks and pops are not really a concern once you're above low-end gear? I mean sure there are some but they're faint and kind of part of the experience.
there are some excellent ADCs reviewed on the site with almost all of them having a noise floor low enough for LP records. Just incase you wanted to feel more 'fancy' and 'pro'. Almost anything can work as an ADC for vinyl after a phono-stage.
The issue isn't "low-end gear" nearly as much as the lack of quality control with the discs themselves. Clicks and pops are real. If one is buying/listening to LPs for musical content, clicks and pops are a problem. If one wants a collection of "demo discs", then one gets rid of noisy records. But if it's maximum fidelity for the music you want to hear, look elsewhere.
The Puffin looks great, but I'd like to see a USB output for computers on it, too. Looks like they just dropped a firmware update last year, it's nice that they keep on improving it.
Yeah, but the real-time de-clicker just might beat out the lower noise floor and distortion of the Cambridge Audio Duo. The noise floor of the discs themselves is higher than the noise + distortion of almost any phono preamp.
Anyone here saving their vinyl disks to digital? What equipment do you use? Anyone just playing their pre-amp output into their motherboard line-inputs?
Most of my listening is portable digital, so I do transfer LPs I enjoy.
Technics 1200 Mk II
Denon DL-103R
Pro-Ject DS2 USB (not using the USB right now, but I have been happy with the results)
Onkyo SE-U55SX2 (ADC)
I've run two tests to measure the accuracy of this setup:
1. Compared rips of 80's era vinyl to CD rips of the same material. Very close, sound-wise. Close enough for me to be happy with the results.
2. The Onkyo is a recent purchase (in a sense it is a vintage 24-bit ADC, dating from close to 2010). I tested it by streaming from the computer to a wireless receiver, sent that to the Onkyo and recorded the stream. So a D-A-D process where I was able to compare the starting file and the recorded one. I was shocked at how identical they files were. Bit for bit, waveform to waveform, they looked nearly identical. No noise from the Onkyo at all.
So to my mind the chief elements of this that define the character of these efforts are the cartridge and to a lesser extent, the noise floor of the Pro-Ject. Used to have it above my amp and there was more noise. I got it away from there and it is now very quiet.
