mvnchies
- Joined
- Jan 17, 2019
- Messages
- 101
- Likes
- 48
Hi everyone. Not sure this is the right part of the forums for this but...
my USB DAC on my TV seems to trigger some copyright protection and disables playback with Netflix and other services.
my solution has so far been to use Bluetooth on a Loxjie A30, but it just doesn't sound as good as when I used USB.
I'm wondering if there's any other solution, or if I'll need a new DAC.
HDMI DAC are so expensive and seem subpar, and I don't need surround sound or anything.
I can't figure out what Bluetooth codecs I can use for my TV either - but it's a Samsung QN90A TV with "Bluetooth 4.2", as that is all I can find about it.
to be honest, I would love to have an all-in-one unit with DAC and amplifier (2.0 stereo) like the Loxjie A30 I have, but that I can also use with the TV...
Latency over bluetooth is a little bit annoying when gaming, but it seems like the TV adjusts for it with video - at least on Netflix... no issues with music playback obviously.
but if there's a good codec that my TV could support, that would be a decent option.
my speakers are Arendal 1961 towers, they don't need a lot of power for the volume I'm playing them at - so if I do find a combination unit... I guess the amp doesn't need a lot of watts.
but I would love to have class D or similar that doesn't run too hot or use a lot of power.
looked at HDMI extractors but I can't find any "measurements" or anything.
so to summarize:
USB audio no go...
some solutions I've thought of:
new DAC+amp with better Bluetooth than Loxjie A30?
one of those HDMI extractors? for some reason the optical doesn't work at all with my Loxjie A30 from TV - and the coax connection (from my PC) basically drowns everything in a harsh loud noise. don't know why but it really sucks. maybe try to find something that actually works with optical? I wonder if it'll sound as good as the USB does?
... HDMI DAC? I can't find anything affordable though. HDMI receivers basically... they seem to cost at least 1000 euro here, with really poor performance. HDMI licensing seems so expensive...
I've also tried looking for some kind of "HDCP disabler" USB device but I don't think this exists. or bypass or whatever it would be called, that allows me to go HDMI -> USB -> USB DAC in.
sorry for the long-winded post, hope there's an easy solution for me somewhere! thank you!
so to summarize:
USB audio no go...
