Small DAC/AMP with sub-out?
Ttimms
Hi all, I am currently using a Loxjie A30 and it does everything I want but unfortunately I'm experiencing audio stuttering when using optical input from TV. After doing a bit of research it appears this is a known issue with the Loxjie so I am looking to buy another small DAC/AMP combo. I need it to be small enough to fit under my TV, have a remote control, sub-out and be able to power my Dali Oberon 3 speakers efficiently. Can anyone give me some suggestions?
If you like the Loxjie A30, take a look at the Loxjie A40. It has an HDMI Arc input that works well. More inputs and more power than the A30.
If you can find one, a MicroMega MyAmp. The latter (better) version has the Bluetooth Pairing button on the remote.
Not sure how much power you need. Drives mine to hearing damage levels. The sub out is good quality, it is fixed,think it is <200 Hz. The subs low pass cuts off lower.
I have also bridged to get more power. A bridged pair could drive stereo subs.
Excellent thanks all. I will take a look at the suggestions.
