Unlimited FIR taps? yes please
Davide
Milan, Italy
Define “right impulse response” and “transition band”.
What do I have to define exactly?
I mean, it's not like they are concepts invented by me.
That is to say that a Dirac pulse is perfectly preserved out of the crossover attenuation band, where normally this does not happen with minimum phase filters.
At least that's what I learned from Uli's White Paper.
Though About Crossovers by Dr. Ulrich Brüggemann
If I am doing something wrong, please correct me.
dc655321
No, i wouldn’t say you’re doing anything wrong, just using odd phrasing.
theREALdotnet
Davide
Milan, Italy
I have to translate everything so maybe some terms are not properly technical. I'm sorry.
Ra1zel
Poland
The high cost (and power) of GPUs, especially now, has (and will) likely keep them out of mainstream AVR/AVP units
Cost is going down now and hardocore AV fans still use them, just look at MadVR Envy Extreme video processor.
SpaceMonkey
Successfully running my own GPU FIR filter, the code looks terrible but I'm gonna clean it and post it on GitHub, unfortunately vacation starts now and will be switching over to a Mac, will be able to tune it for mac users and make it cleaner, not much time until August.
Currently running 12 channels @ 64k taps @ 192khz @ 2048 samples = 1.024 Million Taps
and the load is... 4% on a Nvidia RTX 3080, 50% load for Max 8's
I should be able to bring that 50% down to almost nothing once the CPU side of things gets multi threaded (one thread per filter)
Right now this is a MAX 8 plugin, porting it to VST3 should be easy, or anything else interesting.
It is based of OpenCL instead of CUDA so should be compatible with Intel, AMD and Apple GPUs.
Max 8 has a FIR filter (buffir~) currently limited at 4096 taps max across the entire app, it is pure CPU and single threaded.
And if you don't know Max 8, you are missing out!
Hi, any progress on this?
