Robbo99999
Although at 94dB headphone sweep measurement the gap between the two lines would be a lot less, because that's just how dB works (as well as our sonic perception). (I'm betting you could work out or measure the difference of an identical headphone frequency sweep (no headphone position change on the device) in the two different rooms to really ascertain the difference between the two in terms of how much it can affect the reported frequency response.)For grins I set up a pair of calibrated GRAS 40AG microphones; one on the bench next to the APx555 and APx1701 with cooling fans running. The 2nd microphone was set up across the hall in a bedroom with two closed doors in between.
The ambient noise was significantly lower across the hall from the instrument fans.
Thanks DT
View attachment 120822View attachment 120823
(Plus the headphones will attentuate the background noise to varying extent depending on headphone design - eg closed back vs open, and you measured without any headphones on the ears).
You'd really have to measure a few different headphones in the different rooms to see the effect of the background noise, and you'd have to make sure that the headphone position wasn't changed at all when comparing measurements between the two rooms, i.e. you'd have to leave the headphone on the device without remounting it as you move it to the new room, and be certain that the headphone hadn't changed position accidentally as you moved the device (ie you'd measure it back again in the original room to confirm the measurement was the same).
