Recommendation of headphone amplifier with measurements as good as Topping but more powerful
LETRA
Madrid
Hello everyone. I am scanning the forum in search of a headphone amp that is as good in measurements as my Topping DX9 but has more power. I want to use it with high-demanding headphones of the T+A Solitaire P, Hifiman Susvara or Immanis type, but without losing the clarity and transparency of the Topping. I recently bought a Flux Mentor (good review and measurements on ASR https://www.audiosciencereview.com/...inside-pictures-and-a-few-measurements.53804/ ) and have been using them with a Solitaire P and have not been convinced at all. The sound is good, but it's much better with the Topping DX9, which I just find lacks the power to drive these Solitaire P headphones. Everything sounds better with my DX9 and the Hifiman HE1000 Stealth, but I don't want to give up trying headphones that require a more powerful amp. Is there an option? What is the most powerful headphone amp at the top of the measurements? Thanks for your help.
Solitaire P
Max Power:
Topping DX9
Are you using the Balanced Output?
Or the High Gain unbalanced?
Or what?
The spec for the Topping says it should probably be able to smoke your phones with the high gain balanced output.
(voltage corrected for RMS of the peak to peak voltage)
Thanks for your help. Yes, I am using XLR, but it still doesn't uncover their full potential. The Solitaire P's are sold as a kind of Susvara, but easy to drive even by a DAP, but they don't really extract the most out of them, something I do get with the DX9 and HE1000 Stealth's. Connecting the Solitaires to the Flux Mentor there is more power, more technicality, more soundstage and dynamics, but the sound is less clear and transparent than on the Topping. So I would like to get something that is as good in measurements as the Topping but has power to drive the most demanding headphones.
My reply above modified a little...
The calculator tells me that the Topping DX9 would have about 16.6168500V total RMS in dual channel (8'3V RMS per channel). And Flux Mentor would be at 22.4V RMS total (11.2W RMS per channel). I would look for something with the best measurements, but that could reach at least that 22V RMS. There doesn't seem to be any.
You're confusing Watts and Volts.
Also, V RMS do not add between channels.
8.3Vrms per channel does not become 16.6Vrms total.
Here's the Maximum output power vs load for both Amps:
And here's what that translates to in terms of perceived loudness:
However, I can tell you right now that what you perceive as "more power, more technicality, more soundstage and dynamics" out of the Mentor is not a matter of available output power and as such, replacing the DX9 with an even more powerful Amp will not get you closer to that sound.
What you're hearing is either a nonlinearity in the Mentor that's not present in the DX9, or simple confirmation/loudness bias due to a lack of controls while comparing.
With the help of a basic $10-15 multimeter, you'd find that you're likely using less than 10% of the available output power of your Amps.
With the same multimeter you can perform precise level matching to remove loudness bias, though you'd still have to listen blindly to exclude bias altogether.
Ok. I don't fully understand the technical underpinnings of all this, but I understand what you're telling me. In any case in the measurements that have been made of the DX9 and the Flux Mentor are better for the Topping, except that of the RMS power. Is there no headphone amplifier on the market that has as good measurements as the Topping and yet is more powerful? I'm sure from all the opinions I've read on the internet, even on ASR, that headphones like Susvara or Immanis need more powerful amps than the DX9 to sound even better.
:D :D :D :D
:D :D :D :D
More power/voltage makes the headphones louder. That's it. (Up to the point where the amp or headphones distort. Then non-linear things happen.)
If you don't turn it up and use the power, a more powerful amplifier doesn't make any difference. If you can turn-up the volume louder than you normally listen and you don't hear distortion, more power won't change anything.
But going louder can cause different perceptions, including the fact that as you turn-up the volume it sounds like you've turned-up the bass even more and when you turn-down the volume it sounds like you've turned-down the bass.
:D :D :D :D
:D :D :D :D
Yup. This is what seems to confuse people. Headroom does not have a sound. Assuming two transparent amps with different power ratings the signal will be the same if you stay (when comparing the signals at the same level) within the clean performance envelope of the less powerful amp.
I found before that there is both current and wattage. There were a couple headphone amps that have a spec of a certain amount of wattage; but my Aeon (14 ohm) essentially was missing all bass while using that amp. So something with more current was needed to make the headphone come to life. This is also part of why Amir started testing headphone amps at 50mv output, to see where they performed on IEMs and other sensitive headphones. Since full output power can be deceiving since none of us should be listening to our amps at MAX volume.
Today though most amps have huge power output ratings and deliver plenty of current for even low impedance planar headphones.
If you hear them clipping it could be low current, tube amps especially
It wouldn't sound like the clipping I am used to hearing. The bass was just absent entirely. Which is what happens when you plug a headphone into an amp that doesn't have enough power for it. However the amp actually did have enough power and could handle headphones that have even 600Ohm without a problem to very loud volumes.
I've experienced the same, output impedance of the amp can cause weird issues too. I have a 30 ohm tube amp that will absolutely ruin the sound of planars, the control is flabby, dynamics non-existent. It could be because it maxes at 3.5 vrms but I've read that impedance mismatch can cause signal reflection and inconsistent current delivery
You need to change what you assume. What is lacking here is NOT power. The Topping DX9 can provide more than enough power for your headphones. Have you been EQ'ing the headphones? If not, try it.
Check out the Niimbus US 5 Pro manual; there's a table with the values.
100 ohms with 25.6 volts and 6.5 watts.
50 ohms with 18.8 volts and 7 watts.
32 ohms with 13.4 volts and 5.6 watts.
Thanks :) but I checked the price first and it is 6000€ in Spain. I have more hope that some Chinese company like SMSL will bring out something for around 1000€ that meets my wishes and their measurements are at the top ;)
I think that is honestly still too much to spend. Have you taken a look at the A90D and similar?
Thanks for the suggestion. The Topping A90D has similar power, and I don't know if a little lower, than the Topping DX9 15th that I use. I once tried it with Susvara and it was underpowered. I have also had Flux Mentor, a high-powered headphone amplifier, and its measurements are average and although it drives high-powered headphones, the sound is not of Topping quality. So I'm just waiting leisurely for high impedance headphone amps to be sold, but as good in measurements as the current Topping or SMSL.
Most of the common HPAs, DX9, A90D, L70, A70 Pro, SMSL H400, Singxer SA-1, etc., only run at +/- 15 volts.
You could try to get a used Violectric HPA V280. It also runs at +/- 26 volts, so over 50 volts.
100 ohms at 23 volts and 5.3 watts should still be significantly more than the usual suspects.
With a bit of luck, you can get one of these gems for just under €1,000. That's still much more sensible than sinking it into irreparable devices. Its lifespan with daily use is about 25-30 years, so it's not a risk even if it's used. It can be repaired and overhauled inexpensively by any workshop.
Alternatively, you could also try an HPA V200, which you can get used for €400-500. It also runs at over +/- 30 volts (i.e., over 60 volts total voltage).
I also know several users who run their Susvara, HE1000, etc., with this amplifier and never have to crank it all the way up.
I definitely can't crank my HE6se V2 all the way up on my Violectric HPA V200 (basically half a V280) at 0 pre-gain. At 12 o'clock, I reach my maximum listening volume; from 3 o'clock onward, it becomes unbearably painful, and the volume control goes all the way up to 5 o'clock. The HPA V200 is, of course, only an SE amplifier, but it also has two pre-gain stages, +6 and +12 dB.
The two Susvaras, various HE1000 and HE6 versions, all ran smoothly with the V200.
For the same maximum listening volume with the Topping L70 connected to high gain and balanced, I have to set it to -24 dB. It becomes unbearably painful at -12 dB.
