For what it's worth, I got the following results for my Ortofon 2M Red using the following:
Behringer UCA202 as capture device
Douglas Self-designed Precision Preamplifier for RIAA
TrueRTA software
Audio Technica AT120USB turntable
Analog Productions: The Ultimate Analog Test LP AAPT1, Side 1 Track 6
I was disappointed that the test lp did not contain a contain a continuous 20 Hz to 20 kHz sweep as I'd have liked to see the effect of the preamplifier's low frequency filter. Otherwise, I got similar results from 1 kHz to 20 kHz when using the LP120USB's built-in preamplifier, including rising high frequency response at 20 kHz.
Question: If the use of DSP is assumed, how cheaply can we achieve good-as-it-gets LP playback: Maybe a $250 MM cart with decently low distortion and quiet phono preamp and MiniDSP 2x4HD are all that's needed?
