Hi Sal1950,
The error in this line of thought is the engineer "signed off" on what he heard at the console, not what that would sound like after the vinyl playback process added 5% distortion, wow, flutter ---------------------.
No error.
Did you perhaps not notice I wrote:
"The vinyl versions would have been what the mastering engineer intended and signed off on, so would represent that historical encapsulation of the music as sold to the public"?
The engineer surely understood he was mastering for turntables of that period and had an idea of how it would sound coming off a turntable - hence that was his target.
Also, I'm unclear on your claim about "5% distortion, wow, flutter." Do you mean 5 percent distortion in addition to wow and flutter? If so, which distortion are you referencing? If you mean 5% wow and flutter distortion, that would seem awfully generous. I'm no expert in this, but I've read that W/F below .19% (decimal/19) is inaudible for most people. And even an old Acoustic Research AR-XA can measure down to .13% W/F.
I've seen W/F measurements for the Lin LP12 at .07%.
Any digital copy of that master, even if the monkey decides to squeeze the DR a few points, will still be miles closer in Fidelity than a vinyl playback.
Here again..."miles" doesn't sound terribly quantified. Rather, a description of your opion as to the effect. As I said, I've compared digital and vinyl versions of the same album from the same original masters, and I certainly did not find "miles better" to be an apt description of any difference I heard.
So then what is there to "take issue" with?
Personal characterisations - "X would cream Y" etc - used to imply the claim is an objective fact, rather than a personal assessment, which can therefore mislead the degree of difference one actually might hear in such comparisons.
After reading a full page of your subjective preference justifications, we fall back to the same ole same ole. Is accurate High Fidelity your aim, or personal preference.
A mix of both ;-)
I highly support those engineers seeking ways of reducing distortion in capture and playback of sound. I'd love it if we end up being able to reproduce real acoustic music in a manner indistinguishable from the real thing. And I do generally like speakers that are low distortion/neutral.
I work in sound post production, and I'm used to hearing my work played back in professional mixing theaters. I had my own listening room designed with the input of a professional acoustician. So I appreciate even, smooth playback of my sources.
However....
I have no qualms about slightly seasoning my sound to taste for several reasons. 1. There is no perfect sound reproduction system, so most of us select our own balance of compromises to one degree or another. 2. I adore the qualities that live voices and instruments produce, and I seek in my system to re-create some of that character. 3. Source quality is obviously massively variable. I want to hear the important differences in mixes, production etc. But my main aim is to actually *enjoy listening* to music through my system. Therefore I'm fine with tiny introductions of distortion - be it from tube amplification or sometimes vinyl - that nudges the sound in a direction I enjoy, and which helps me subjectively achieve goal #2.
So...no...I don't just throw all notions of accuracy to the birds.
But yes, I nudge the sound in the direction pleasing to me. Note that Floyd Tool has no qualms with altering the signal to taste either and in fact advocates it. Though of course he does it via EQ/tone controls, signal processing like upmixing etc, and would not do it earlier in the chain. Nonetheless, it is still a case of distorting/altering the signal to listener taste.
You just can't defend any vinyl rig (no matter how much your spent and believe you've improved it's SQ) as representing the SOTA in High Fidelity for 2019.
Agreed. Which is why I did not make such a claim! I made it clear right at the beginning of my post, and re-iterated along the way, that I did not believe, or claim, vinyl could be SOTA in accuracy. I said even a cheap (well made) digital source beats vinyl.
