shal
Hi,
Just for fun, I try to measure the quality of my DAC with my Field recorder Sound Devices mixpre10 ii
First item : Lavry DA11
It's a DAC build by Dan Lavry , quite old (2009) USB, optical, spdif input, XLR (balanced or unbalanced) output, headphone.
http://www.lavryengineering.com/products/da11.html
Main characteristics from site :
Dynamic Range: -112dB typical, -110 dB minimum (Non weigthed )
Second item Sound Devices MixPre-10 ii
https://www.sounddevices.com/product/mixpre-10-ii/
-130dBV (-128dBu) max (A-weighting, gain=76dB, 150 ohm source impedance)
ADC : 32 bit precision; 142dB dynamic range min (A-weighted, gain=10dB, fader=0dB)
I am under Linux, so using windows soft is sometime weird to manipulate . I use the wine software in order use windows program on Linux.
So the test I have this configuration:
RMAA.exe -> wine -> Linux (alsa) -> optical -> Lavry DA11 -> XLR cable -> Sound Devices MixPre10 ii -> usb cables -> Linux -> RMMA.exe
The volume setup:
- Linux/alsa volume a 100%
- Lavry (I do test a different volume and obtain different measures)
- Sound Devices a input a 0
I have made different measure with Lavry volume.
At the maximum RMAA says that the level is to high
I made test to 40, 48 and 50
Noise level is better at level 40 : -115 that at 50 -109.2
Dynamic range is better at 48 : 116.1 than at 50: 115.9 or at 40 : 114.9
Intermodulation is not very good 0.041% at level 50 and 0.022% at 40
Crosstal betwwen -108 and -110
This is the spectrum for Lavry at level 50 :
This is the output level of the Lavry :
That all folk. it's just for fun
I am happy from the result
If you have advise to perform better measure , doesn't hesitate to spoke.
Olivier
The volume setup:
Olivier
