I am considering replacing my bookshelf (PMC DB1) speakers with tower speakers. I have the room for towers and my room size is ample, but with so much discussion about bookshelf speakers here and products like Buchardt, I'm really wondering exactly what the upside of tower speakers are. I do not play music loud and have a sub. Is tower vs bookshelf still a quality of sound issue? Are people now tending to go with bookshelves for almost all situations that do not involve loud music?
Howdy, I do listen often at medium loud/loud (not headbanger but deff attention getting. 82-88db with peaks at 95-100db, speakers 8 feet apart 10 feet from me)
I mainly use bookshelves and at least two subs.
My room is a "medium" size.
I like to switch speakers often and monitors are just easier.
I nearly always high pass my monitors and they can cope very well with my volumes such that if you are not going loud no you have nearly zero
need for floor standers. That said unless you plan to switch speakers often like me why not just go floor? The space they take up is similar and the ease with which they play, the increased dynamics and increased sensitivity are all worth it for those louder times. (even if the gain over excellent monitors are sometimes minor, they are gains)
Some folks here have mentioned integrated amps with sub-outs. IMHO Forget about that. Buy a budget miniDSP Hd for $200 and a decent budget 2 channel amp for the monitors/floorstanders and mate the whole thing with two active subs. The PEQ and active crossovers will easily outduel any subtle gains in SQ that expensive integrated amps have over a budget 2 channel that it simply makes zero sense. Complete waste. Nothing will help you integrate your subs better than highly adjustable and configurable electronic crossovers and whether you have floor-standers or monitors you must have PEQ or room correction software. Additionally some more of the best gains I have experienced with monitors and subs are due to high passing the monitors - even at medium volumes the clarity gains are quite nice when those little woofers don't have to bump near and beyond xmax and simultaneously play pretty voices. (at low volumes this might not matter & with some really robust gear)
by the way if money is not an issue and looks are important this seems decent.
Has Dirac built in and plenty of power and other great features,
https://news.harman.com/releases/releases-20210105
