Absoloosely.Excellently written response. Thank you!
If you don't have digital files (flac, wav, etc ) the M50 has no value for you. Your setup is just right.I'm writing this inquiry from an almost complete lack of knowledge concerning the question of what role the Topping M50 plays:
Currently, I hardwire connect my iPhone 8 to a Topping D90SE. The D90SE feeds a Topping A90 through to a Topping PA5 which drives a pair of Revel M16 speakers. Topping cables are used throughout (except between the phone and D90SE and when connecting the PA5 to my loudspeakers). I sometimes listen to Tidal streamed music using Dan Clark Aeon Noires.
(1) I have no idea whether this is the 'proper way' (highest fidelity way) to play music streamed from Tidal (my primary music source), although the music generally sounds mighty good to me;
(2) Would adding the M50 to the audio chain described above (between the iPhone and D90SE) serve any fidelity related purpose?
Please feel free to educate me. I'm just starting to grasp digital music reproduction. Thank you all!
Jonathan
Another one at $42. Using Hifiberry driver (I imagine most of these chinese generics uses Hifiberry driver like most generic HAT) and seems to work with Moode/Volumio.OK, sorry, I meant a cheap alternative to the Pi2AES (that is even discontinued unfortunately).
The problem with those chinese generic hats is the official support on OSes like Volumio for example
Good for you. I have 6 streamers that do that far more efficiently. It is so worth it to not waste 30+ minutes entering a password. On a par with ignoring the MQA scam.
Mine goes Toslink and coax to a E50. My coax cable sounds much better.
Also I use M50 as DLNA to listen my Synology music
Is there no volume control in this unit for airplay ?
When I connect my DAP to the M50 via usb, M50 charges my DAP. In such cases, the M50 acts like a host device and accesses the DAP's storage to play files from the it.My plan is to use this in my vehicle. I’ll plug this into usb power in my truck, and use this to DDC my iPad to digital coax to my DSP. I’m currently using a Topping D10 for this, but this looks like it’ll add USB drive input as well. Which is a welcomed addition to me. Any measurements on this? I’m also curious is it provides power to the usb device when using phone/tablet as source? I’ve just placed my order.
Or a DAC with control, at least remote like an E50.I’m still waiting for mine, but I don’t believe there’s a volume control for any input. This streamer is entirely digital, and intended to serve an amplifier for which you’d have analog volume control.
No. It is the most byzantine entry method ever. If you can do it quicker have at it.Are you saying you have to enter the password more than once?
Worse than a handheld device (illegal here) while driving.When I connect my DAP to the M50 via usb, M50 charges my DAP. In such cases, the M50 acts like a host device and accesses the DAP's storage to play files from the it.
