Topping LA90 evaluation and discussion (Integrated Amplifier)
Rate this amplifier:
    Votes: 8 11.6%
    Votes: 8 11.6%
    Votes: 11 15.9%
    Votes: 42 60.9%
GeekyBastard
I would bet 100 euros the gain will be below 10 dB lol.
Annnnnd... you just lost 100 euros.
FireShot Webpage Screenshot #029 - 'Measurementsof Topping LA90 PowerAMP 拓品LA90 - L7Audiolab' ...png
There is a high and low gain switch on the rear panel. I saw a comment in an ASR post saying he was willing to bet 100 euros the gain of the LA90 must be below 10dB "I would bet 100 euros the gain will be below 10 dB lol." So let's examine the high gain Dashboard:
The same can reach 120, and in the power curve that follows, we can also see that there is almost no difference in the performance of high and low gain!
Matias
São Paulo, Brazil
So 2x90W in 4 ohms for this ultra-silent amp. Desktop users rejoice, living room users look elsewhere.
Lindirizzo
bkdc
And from a local supplier - no worries about warranty support. Admittedly not integrated, but I have MiniDSP flex already on order which will be my preamp.
This one is not for me I think.
Do you know of something similar to the miniDSP flex but with BALANCED inputs and outputs? Does this come with a TRS balanced option?
TheBatsEar
Germany
Topping offers with its LA90 a powerful and efficient amplifier, which can work both in stereo and mono mode. In the first case, it is capable of delivering a power of 2x90W under 4Ω (1% THD+N), in the second it will be able to provide a power of 180W under 8Ω (1% THD+N). Moreover, the LA90 provides a combined balanced input connector, the device being able to be connected as well in Jack 6.35mm as in XLR.
900 Eurobucks at Audiophonics, 749,17€ (US $802,53) without VAT.
abdo123
Brussels, Belgium
abdo123
Brussels, Belgium
Matias
São Paulo, Brazil
Topping dominating the low power value.
TheBatsEar
Germany
publicly humiliate
Wasn't meant like that, i'm sure of it.
I bet Amir is fixing last minute things in his review ... hurry, hurry, mate!:p
Matias
São Paulo, Brazil
WolfX-700
China
Next time when he wants to publicly humiliate me perhaps he should do it while measuring power at 5W or 1W instead of arbitrary power outputs at 25W and 50W.
He is obviously maximizing the noise part of SINAD this way.
Eitherway i’m very impressed.
If you feel offended, then I apologize to you. A big reason for using 25W to measure at high gain to achieve 120 SINAD is that the signal generator of the APX555 can only generate a signal with a SINAD higher than 120 at the corresponding amplitude (slightly more than 1VRMS).
TheBatsEar
Germany
Maybe just me, but this is awesome for 900€!
Matias
São Paulo, Brazil
