Topping E70 Stereo DAC Review
Rate this DAC:
    Votes: 8 2.0%
    Votes: 8 2.0%
    Votes: 48 12.0%
    Votes: 335 84.0%
Is this review of standard E70 (ESS) or E70 Velvet (AKM), is there a review of the Velvet?
Standard. No velvet review
As far as I can tell the E70 velvet doesn't use a current to voltage stage like the ESS chip version. It uses the AK4191 chip with the 4499EX
Why do you think it wouldn't have an I/V? AFAICT the 4499EX has much the same kind of outputs as the AK4499 (pre-fire) used to, and that very much needed external I/V:
Looks like my E70V might be defective. It powers off randomly. When I turn it on again, it stays in standby mode. I have to unplug/replug the dac to get it working properly. Tried several factory resets, but the problem returns every time. Anyone with an E70 or E70V have this problem? I've already got an RMA going with Apos Audio.
No problems on my end E70 and L70.
Looks like my E70V might be defective. It powers off randomly. When I turn it on, it stays in standby mode. I have to unplug/replug the dac to get it working properly, again. Tried several factory resets, but the problem returns every time. Anyone with an E70 or E70V have this problem? I've already got an RMA going with Apos Audio.
Do you use it balanced or unbalanced, A ground loop can be the cause.
No idea the one I got was a brick. I've had an RMA going with Apos since the end of December.
It's already packed up for the return trip to Apos Audio. Time to focus on my next dac. Right now, the leading candidate is the SU-9 Pro. I'm not interested in spending more than $500 on a dac.
Better S.M.S.L. M500 mk3
