Topping E50 Review (Balanced DAC)
777
Hello. Can I have 16bits in the Topping Device Control instead of 24bits or 32bits ?
Rottmannash
Nashville
Why would you want that?
Rottmannash
Nashville
Because in Tidal I have many crackling and the MQA could not stay because of that.
Don't think it has anything to do with the sampling rate, but someone smarter can probably confirm or refute my statement.
ceausuc
If you want to discuss perceived sound quality, this is not suitable forum for that. Attackers are ready to jump here and to gain their 'valuable' likes points by teaching you that you cannot hear any differences between DACs of this category.
Yes, as someone said: "measurement police" is always watching and keeps repeating this "all dacs sound the same".
One has to wonder how come they never get tired... is it a hobby or a job? :)
Toku
Japan
Since E50 can play up to 32bit, normally select 32bit. If you do not play 32-bit files, you may select 24-bit.
777
Have you activated exclusive mode on Tidal for E50 and passthrough MQA?
Yes. In that moment the sound start to crackling, in the "exclusive mode", when the Tidal application take entire control.
Lokitay
Does anyone encounter the same error as me?
Asma
My e30 was showing error E -1 when I connected the wrong power supply, solved this problem by replacing it. Write to the topping company support, they will help you.
[email protected]
PKAWA
@amirm Please upload a better resolution graph for the sinad score. The last reviews all have an unreadable chart.
Walter
The problem must be on your end--the SINAD charts on this review, as well as those from the last few days, have all been fine.
TSky
Greetings, this is my first post, and English is not my native language. So, sorry for possible mistakes. I'm facing a choice, d10s e30 or e50. The price difference is decent, but will there be the same difference in sound between them? I just need a dac to replace my old one that broke. I listen through a Senkhi hd 650 and a tube amp. What would be better? Does it make sense to buy the E50 right away if I don't need its functions, or is the d10s enough to play just a good sound? Judging by the measurements, they all show exorbitant results, up to 120db, the difference between them is 2-3db and the price is $ 150 -)
Haruko
if you are going to use tube amp i don't think you will hear difference between d10s and the rest
TSky
Will the tube amplifier color the sound and, as it were, "level" it between all the DACs? Is there a problem with interference via usb, because the "especially d10s" DACs are powered via usb. This nuance is very confusing.
