Are you powering the E30 from a port on the PC?It fails to turn off as long as the PC is on even if I close the audio player. I have no interest in turning off the PC.
Well this gent also found audible difference in sound using different filters, something none here can confirm.. Maybe he's got the golden ears..I just got my E30 and am about to hook it up to my power amp. One of the major reasons for me to get it was not having to use a separate preamp. This topic has been discussed a few times in this thread & I'm fairly certain I would not "lose" anything by using it in preamp mode vs dac mode. Pray tell then why this gent (at 8:45) scoffs at its preamp performance?
does anyone have a cheap, reliable way of switching optical inputs?Any subjective impressions that aren't acompanied by a rundown of which measures were taken to eliminate placebo aren't worth discussing.
Here's how to do proper, blind testing:
Here’s mine….^
Thank you. Wow, there are a lot of differences. In fact a lot more than just a swap of receiver chips. There are even quite visible differences to the output stage. No wonder it sounds different to earlier versions. The power supply stage has also severely changed. This new E30 has to be re-reviewed by amir. I'm calling it out! (green=same as before/red=changes in the circuit)
That should be some kind of buck converter, changing a voltage (say power supply 12V) to another voltage (say 3.3V or 5V). If you measure what is coming in and out of the pins you should be able to locate similar parts. I doubt the label helps much, it often is just a batch number. Format appears to be 12pin MSOP.Hello everyone, please help me to identify the chip on toping e 30
You can check out this video if it will help you outinterested. compared to d10s is there a big difference?
as a user of the d10s is there a lot of difference with replacing it with the e30?
Any kind of reset?
