ShinMolina
This happens everywhwere, even in ASR.Ooh no here we go again...
The main simple answer is that a complete DAC is composed of the main DAC chip and an amplification stage. Also there are good and bad DAC implementations, the DAC manufactrer almost always recommends and shows an example use/diagram/design. It is the duty of companies to implement the design of the complete device, following or not the recommendations. Then, the differences may come from the design around the DAC, not from the chip itself.Then explain to me why even different DACs from different manufacturers using the very same DAC-chips do sound different?
If we are talking about good DAC chips there is no sound difference if properly implemented. I have multiple ES9038Q2M DACs, one of them has a bad implementation and introduces tons of distortion. However, this is not audible, at least for my ears.
I also have an AK4993 and a Cirrus Logic one, no sonic differences between them, even after blind A/B testing. The only difference is that the Focusrite Solo containing the Cirrus Logic DAC saturates early and can be easily heard because of the obvious clipping.
