It will definitely be better matched on the SE output. Over XLR you increase the chance of 'muddying' the sound I'm afraid, due to x2 output impedance. So unless you want more bass..If i was the run Focal Clear Pros via XLR on this would the output impedance cause an issue? Really had my eye on this to run as a combo unit and as dac to my other balanced amps
Thanks for the reply. That is a shame. I may just get another SMSL SU8 and SP200/Monolith 887 then.It will definitely be better matched on the SE output. Over XLR you increase the chance of 'muddying' the sound I'm afraid, due to x2 output impedance. So unless you want more bass..
Actually would it probably be better to get Sabaj D5 instead?It will definitely be better matched on the SE output. Over XLR you increase the chance of 'muddying' the sound I'm afraid, due to x2 output impedance. So unless you want more bass..
You could plug a low impedance amp in the DX7. D5 has no such issue so that is another option.Actually would it probably be better to get Sabaj D5 instead?
Will have to have a look. I was looking at either dx7 pro and d5 just because they are balanced through. Suppose I could get rhe dx7 pro and sp200You could plug a low impedance amp in the DX7. D5 has no such issue so that is another option.
Or you can just use single ended on DX7 Pro which is probably fine, too. All are valid options.
I'm getting the sp200 myself. I will max out sp200 in low gain, and use dac+digital volume control. Seems perfect for my needs.Will have to have a look. I was looking at either dx7 pro and d5 just because they are balanced through. Suppose I could get rhe dx7 pro and sp200
Well currently I have a SMSL SU8 going to a Loxjie P20 and JDS Atom. But obviously I've maxed out the outputs on the SU8I'm getting the sp200 myself. I will max out sp200 in low gain, and use dac+digital volume control. Seems perfect for my needs.
Any good DAC with volume control should do a fine job here.
So I have been offered a Benchmark DAC3 HGC for the same price as the DX7 pro. What would you do?
Despite the topping having 'better' measurements, would you still consider the benchmark a better device? I intend to get a THX 887 when possible too.I'd take the DAC3 and ran.
OK thank you kindly for helping!It may measure a tad worse, but overall it is definitely a better device. I'd probably skip the THX too and just used the Benchmark directly.
I'm also interested as to why you recommend against the TXH?It may measure a tad worse, but overall it is definitely a better device. I'd probably skip the THX too and just used the Benchmark directly.
Yep it's a DAC 3 but the owner is a close friend of mine and would be doing me a (huge) favour! The topping's measurements intrigue me, as does the benchmark's reputation, build quality and features. I feel the topping may be more future-proof but the benchmark is a classic in the making... We're getting into subjective territory here :OAre you sure it’s a DAC 3? Even the non HGC model is three times the price of the DX7 Pro.
I’d choose the benchmark, sell it and get DX7 Pro and pocket $750.
I received mine yesterday and am impressed indeed. Even the build and stature seem to have improved. I am only using it in DAC mode so far but it’s clear that there’s not really much more to gain from a performance standpoint.
Is APOS Audio legit,have you used themProbably Apos Audio.
But there may be others who are located nearer to you than them depending on state and stock I suppose. There is a member of the trade on this forum who carries Topping and is based in Texas. (Sorry his name escapes me at this moment. )
