meinhard57
- Joined
- May 27, 2020
- Messages
- 31
- Likes
- 24
Yeah - I would guess so - but I can dream or wish, right?
After using the DX7 Pro pretty extensively in my office, I may have to re-think the main listening setup. I sure would like to see a DX9 Pro - . The A90/D90 separates combo is fantastic - just think that a DX9 Pro with elements of each could be a great seller for $949 (or thereabouts) list.
Maybe it will be made one day but it's not a priority. Plus, would be hard to stuff the real estate of those two boxes into one.
I think they will need a new enclosure for it. But would be nice to see it happen as topping's current flagship combo unit DX7 pro, which I have is more of a top of the line DAC with a good but not great amp.
It will help you in choosingAs I thought, this was a swindle. Not a big deal though. I'll then probably go for a pair of HD650s or a DT1990 Pro
Contact with TOPPING Technology support & after sales service: [email protected]Please HELP!!!
I just received my DX7 pro from China bought through eBay, and the Bluetooth just drop out intermittently.
No one use BT, or no one has problem? So, I am just unlucky getting a defective unit?
Thank you very much. Sometimes it disconnect faster, sometimes takes longer. But for all my tests, it got drop out within 5 songs.My guess is most people don't use it. Let me test for you real quick
Hello to everyone,
I just received my dac dx7 pro, and i want to ask you, if it's worth it to replace the stock op-amp LME 47920 of headphone amp with betters one like, for example, Sparkos Labs SS3601. Thank you in adavance for you answers.
My phone only let me pick LDAC, and I picked highest quality, on 5th song now, been 96khz steady, put my phone in next room and works fine too. So I guess you do need to contact sales for return or exchange.
Thank you for the test.
BTW, how do you pair? In other Bluetooth speaker or headphones, I need to get into pairing mode first. But for DX7 pro, it seems it is right there for my phone to discover. Is it correct?
I think I found the problem! It is the antenna! I unplug the antenna and plug in a old TV coaxial cable, and no more drop out. This is crazy. The support is actually right, maybe it is a common problem. But there is no visible damage on the antenna. The pin or wire inside is thin and short, I guess there is a poor contact.
Damn, no, it doesn’t work. It just got dropped out. But definitely a lot longer without drop out. Gosh, I give up.
Definitely it is related to the reception. I did one last test. I don’t have any antenna and coaxial cable, place the phone directly behind the unit, it played the whole CD without drop out. I think a coaxial cable is not a good antenna because it is shielded. I cannot understand. Most Bluetooth device nowadays do not have antennas, and they can still receive signal. The dx90 doesn’t have antenna. How come the antenna is so critical for this dx7 pro?
