staticV3
- Joined
- Aug 29, 2019
- Messages
- 8,189
- Likes
- 13,177
Technically yes, but the difference is not audible.Is this better than Topping D50s (dac wise?)
In what way? Considering that I'm thnking to upgrade my Atom - D50S setup, for better features, this would be the way? I'm trying also to figure if DX3 pro + is better than FiiO K7 of which I like the balanced portTechnically yes, but the difference is not audible.
The DX3Pro+ is a better DAC than the D50s (less noise, distortion, jitter), but the D50s is already good enough to sound 100% transparent to the human ear. So the improvements of the DX3Pro+ are purely of academic nature.In what way?
The DX3Pro+ would be a way, not necessarily the way.Considering that I'm thnking to upgrade my Atom - D50S setup, for better features, this would be the way?
The main contenders for AIOs around $200 are:I'm trying also to figure if DX3 pro + is better than FiiO K7 of which I like the balanced port
| Topping DX3Pro+ | FiiO K7 | SMSL C200 | iFi Zen DAC V2 |
Headphone out | SE | SE+Bal | SE | SE+Bal |
Line out | SE | SE | SE+Bal | SE+Bal |
Line in | ✕ | ✓ | ✕ | ✕ |
Display | ✓ | ✕ | ✓ | ✕ |
Bluetooth | ✓ | ✕ | ✓ | ✕ |
Remote | ✓ | ✕ | ✓ | ✕ |
Excellent comparisons/info~All of them will sound the same, so it's mostly about the featureset:
Topping DX3Pro+ FiiO K7 SMSL C200 Headphone out SE SE+Bal SE Line out SE SE SE+Bal Line in ✕ ✓ ✕ Display ✓ ✕ ✓ Bluetooth ✓ ✕ ✓ Remote ✓ ✕ ✓
Edit: Some other AIOs around that price point are SMSL D12, Loxjie D20, Schiit Hel 2E, iFi Zen DAC V2.
OUTSTANDING reply ! Thank you so much! It's not so easy to pick any . SMSL C200 should have SE+Bal too. SMSL sounds like a great option but I've read that's not so powerfulThe DX3Pro+ is a better DAC than the D50s (less noise, distortion, jitter), but the D50s is already good enough to sound 100% transparent to the human ear. So the improvements of the DX3Pro+ are purely of academic nature.
-Topping DX3Pro+
-FiiO K7
-SMSL C200
-iFi Zen DAC V2
All of them will sound about the same, so it's mostly about the featureset:
Topping DX3Pro+ FiiO K7 SMSL C200 iFi Zen DAC V2 Headphone out SE SE+Bal SE SE+Bal Line out SE SE SE+Bal SE+Bal Line in ✕ ✓ ✕ ✕ Display ✓ ✕ ✓ ✕ Bluetooth ✓ ✕ ✓ ✕ Remote ✓ ✕ ✓ ✕
Edit: Some other AIOs around that price point are SMSL D12, Loxjie D20, Schiit Hel 2E.
as I stated .. I'm a noob.. Well considering power, features, sinad where would you put your money in your list?View attachment 276889
it's a DAC+Amp.
C200 probably.as I stated .. I'm a noob.. Well considering power, features, sinad where would you put your money in your list?
And it was as timed offer on Amazon. Well mate thanks a lot you really helped meC200 probably.
Integrated PSU is nice, UI is supposedly snappy, and I'd appreciate the BT input and Bal Line out for long cable runs. Remote also appreciated.
As for Bal HP out, what matters to me is not whether it's SE or Bal, but how much power it can output.
Hi Tony. I need to use RCA's to my tube integrated. Will I experience the same ground loop?USB is not isolated. It has a common ground, and that allows a ground loop to form between PC to Dac to AMP (expecially if the amp is in a powered speaker)
Impossible to say.Hi Tony. I need to use RCA's to my tube integrated. Will I experience the same ground loop?
I'm just getting into audio. Are all of these units transparent? It confuses me when people talk about how much the sound of their headphones changes in different setups. I just want my gear to be transparent in their default setting.The DX3Pro+ is a better DAC than the D50s (less noise, distortion, jitter), but the D50s is already good enough to sound 100% transparent to the human ear. So the improvements of the DX3Pro+ are purely of academic nature.
-Topping DX3Pro+
-FiiO K7
-SMSL C200
-iFi Zen DAC V2
All of my equipment is connected to a Panamax M5300-PM power conditioner and surge protector, and are grounded to it. However, my tube integrated does not have a ground connection. Figures, huh?Impossible to say.
First depending on how your equpiment is grounded, there may or may not be a physical electrical loop formed. Then even if there is a loop formed, is there a noise source that couples into it of sufficient magnitude to be audible.
Start with a connection diagram of your system - how each component is connected together, how each is connected to the mains supply - and is the mains supply for a component connected to the mains ground.
Then - bearing in mind all equipment grounded to the mains will have all their mains grounds connected together by the wiring in the walls, you can see if there will be a ground loop - especially one that connects through one of your RCA analogue connections.
So all grounds are connected at the power conditioner. Are there any loops in your system that are part made by analogue interconnect.Thank you all very much. My Topping DX3-Pro+ will be here tomorrow, and I found a nice American made active cable for $11.00 just to be sure.
Not that I'm aware of.So all grounds are connected at the power conditioner. Are there any loops in your system that are part made by analogue interconnect.
In which case you are unlikely to have problems with ground loops.Not that I'm aware of.
