J Ratcliffe
- Joined
- Mar 19, 2022
- Messages
- 27
- Likes
- 7
this DAC is overkill for headphones, right?
Why would it be? People use much more expensive DACs than this exclusively with headphones.
Currently, the world situation is very unstable. Therefore, logistics problems can occur at any time. It is safer to purchase products that are shipped from within your country, such as Amazon.Where do you guys buy the D90SE from? A Google search throws up a few possibilities; Shenzhen Audio etc.
There is no guarantee for accidents during transportation for products shipped from China such as Shenzhen Audio. I actually experienced it in the logistics turmoil caused by COVID-19.
You must remember that Amazon UK includes taxes, duties and fees.Amazon UK have none until May and they want almost £900, versus £680 from Shenzhen.
I believe it was designed with HP's in mind but it can be used for speaker systems as well. I use mine for main HT system/2 ch system and a D70 for my HP listening.this DAC is overkill for headphones, right?
I have both hooked up through my pre90 so I can directly compare them.Thanks.
I'd still like to hear from anyone that has compared the D90SE to the Ares II.
The playing to the peanut gallery ASR Appropriate comparison would be to say that at the limits of non-trained human hearing, the Denafrips Ares 2 weighs more than the Topping D90SE due to its linear power supply incorporating a highly photogenic doughnut of a transformer.Thanks.
If your Atoll Streamer is doing the first MQA Unfold (You're going to have to do a deep dive into the MS120 manual to learn about its Tidal Connect behaviour) then the D90SE will display OFS instead of MQA when an MQA track is playing.Hello, I want to ask you for advice. I bought a new DAC Topping D90SE and a brand new Atoll MS120 streamer is connected to it using a coaxial cable. However, the MQA symbol still does not appear on the DAC display although I use the Tidal master service . Please don't know where the problem might be? Excuse my English, I'm a beginner. Thank you.
Velice vám děkuji za odpověď. Již je vše naprosto v pořádku, NA displeji se zobrazuje OFS. Myslel jsem, že pouze MQA je správný popis.Pokud váš Atoll Streamer provádí první MQA Unfold (budete se muset hlouběji ponořit do příručky MS120, abyste se dozvěděli o jeho chování Tidal Connect), pak D90SE zobrazí OFS místo MQA, když se přehrává stopa MQA.
Ale než jsem udělal něco jiného, kdybych byl vámi, zjistil bych, jestli bych mohl dostat displej D90SE, aby zobrazoval MQA nebo OFS při připojení k vašemu MS120 přes USB a přehrávání stopy Tidal MQA.
Yes!would this unit be an good match with the
Audiophonics HPA S400ET?
Thanks
Thanks for you input. I don't know what the f I'm doing.Yes!
Don't fret fam, you'll learn tons from ASR. Welcome to ASRThanks for you input. I don't know what the f I'm doing.
My head hurts so bad from trying to figure what's up. Plus, I don't speak Latin so there's that. But thanks. Anyone here need advise on Optics, Actions, twist rates, b.c.,I'm your Huckleberry.Don't fret fam, you'll learn tons from ASR. Welcome to ASR
There's a full APx555 report on Schiit's website and I have little reason to doubt its contents. It's at the bottom of the Specs page: https://www.schiit.com/products/bifrost-1So I know we haven't gotten actual measurements from the Bifrost 2 over here but I'm assuming it is likely the D90SE is in a completely different league than it? I have a Bifrost 2 right now, considering purchasing this
