Eddy H.
- Joined
- Jul 29, 2021
- Messages
- 133
- Likes
- 71
Buy Buy Buy!OK - I no buy the D90SE then
Thank you very much for the warning. I made sure that the PRE mode was activated & I then started from -20 dB down and incrementally increased the sound level. I can hear through the speakers loud enough. My config isFirst things first.
Get volume off 0.00 right NOW as that is MAX VOL and IF you get sound going........... you will blow something.
Volume starts in the minus as far down as you can go......... IIRC something like -99??
Anyway AFTER dialling volume down go into D90SE's setup menu and select DAC/PRE.
That should do it.
I am guessing a little bit as I had a D90 but I assume they operate similarly.
iphone --> bluetooth --> d90SE --> NAD c298 --> loud speakers
However, I have run into another conundrum since I use my iphone to send music over bluetooth .
I can now control music 2 ways
- by adjusting the volume on my iphone ( i am assuming that here I am increasing volume of the input digital signal )
- by using the topping D90SE remote ( i am assuming that here I am adjusting the volume of the output analog signal )
What is the right way to manage this ? My reading/browsing suggests that volume control of the digital signal is lossy. So I just want to use the d90se volume control. However, I dont know how/what then to adjust the iphone volume levels so that the digital input signal is not messed with.
Thank you for your suggestions.
Every DAC review Amir does includes a ranking of all tested DACs.This is really great performance! But the review is from june 2021, maybe there are dacs with better sinad now?
@Amir Is it possible to get a sticky post on top to see what the current best dac is?
Here's the most up to date ranking that's part of the Topping DX5 review from 26.03.2022:
D90SE is still on top.
Phone at max, use dac to decrease volume. The digital signal is messed with anyway since you are using Bluetooth.Thank you very much for the warning. I made sure that the PRE mode was activated & I then started from -20 dB down and incrementally increased the sound level. I can hear through the speakers loud enough. My config is
Click on "Reviews" in the top left corner.Yeah I know, but how do you know what the most up to date graph is? The threads in this forum are ordered by latest post so I’m not even sure what the last review is?
Easier yes, but that index is not up to date. The latest entry is from 20.10.2021.Maybe easier: Go to "Review Index" -> "Electronics"
Kenny, If I may inquire, what is the test equipment and software that you use ? I would like to set something similar in my shop. Thank you.
Per his screen shot? That's an AP 555 dashboard and it's an image from the website of https://www.l7audiolab.com/ who is on here somewhere.Kenny, If I may inquire, what is the test equipment and software that you use ? I would like to set something similar in my shop. Thank you.
?This ought to liven things up. Had been getting rather quiet around here.
