manisandher
Purely out of interest, does anyone know whether Topping have stuck with a linear PS for the D90 III, or have they gone over to an SMPS, like many of their other DACs?
Mani.
Mani.
That's A-weighted.Topping's own measurements come in just shy of 128dB SINAD
Anecdotal evidence https://gearspace.com/board/electro...rme-ff800-now-10-years-old-should-i-sell.htmlI'm a fan of RME. I loved my HDSP card when I was using it. But, I had two FF800s fail on me, after only a few years of use. My current ADI-2 Pro seems solid though.
I've ended up with a lot of Topping gear, mainly for the fully active system in my office:
- DM7
- DX1
- 3 x LA90
- 2 x LA90D (ordered, waiting to be delivered)
- 2 x PA7 Plus
- HS02
- TP60
No issues whatsoever with any Topping component so far (touch wood). The TP60 is still going strong after 15 years or so.
Mani.
I'd reckon that the audio shop would be far more easier to fix them if they are out of warranty.
Does look like a better remote using Bluetooth though? As reported by @KenA #8 above
Also for direct to power amp operation without a preamp the balance control facility ( similar to D90 SE/LE) might appeal?
False info. D90IIIis not going to have any new firmware on PEQ. This has been confirmed multiple times by sales of Topping.Thanks for the review @amirm
There is a separate thread in which the op said that these III devices (D90 and D50) would be upgraded to have EQ capability. Any additional information on that?
"D50 III has PEQ, and D90 III seems to be updated in the future."
Thread 'TOPPING D90 III、TOPPING D50 III' https://audiosciencereview.com/forum/index.php?threads/topping-d90-iii、topping-d50-iii.50539/
Didn't believe either. The current display is not adequate to have PEQ on this DAC...False info. D90IIIis not going to have any new firmware on PEQ. This has been confirmed multiple times by sales of Topping.
You don't need any display in the unit. You need a smartphone.Didn't believe either. The current display is not adequate to have PEQ on this DAC...
Yes nearly all DACs these days have a volume control but the balance control is perhaps a useful feature for some which is normally only found on a full separate preampThe D70 pro also has a preamp integrated.
Is the improvement just the remote control?
Not denying this is a good improvement. I mean they were offering a $2 remote control on > $500 products....
What is it this balance control? Sorry I missed that featureYes nearly all DACs these days have a volume control but the balance control is perhaps a useful feature for some which is normally only found on a full separate preamp
The remote control improvement may only have cost Topping a minimal amount extra but hopefully it fixes a significant range shortcoming noted with several remotes from them in the past
If Amir included "EQ-ability" in the tests, Topping would have a 2000 band graphic equalizer stuck on the front of this thing in three weeks.For this kind of money, should have 10 band PEQ. We are now at the point where full DSP features need to be part of the expectation set. Time to raise the bar again.
This is all well and good, but is there really any reason to buy this when you can get *almost* the same, already transparent, performance for less than ½ the price with, say, a Topping E70 <https://www.audiosciencereview.com/forum/index.php?threads/topping-e70-stereo-dac-review.39188/>? (There many others now in the same bracket.)This is a review and detailed measurements of the TOPPING D90 III Sabre balanced stereo DAC. It was sent to me by the company and costs US $899.
As you can see, the design is what we have know about most of the Topping products. I do wish at this price that we had a high resolution display that showed VU meters and such. Usability would be better that way although the included remote is easy to use. Back panel is as you would expect:
Nice to see Topping continuing to provide trigger support for automatic turn on of the downstream amplifiers and such.
TOPPING D90 III Sabre Measurements
The DAC has two output setting modes. One that provides max of 5 volts nominal and one that is 4 volts. For fairness I tested using the latter. DAC was allowed to warm up which improved its performance by about 1 dB.
As usual, we start with our dashboard:
This is the best performance we have seen from Topping and is in a virtual tie with the previous king of DAC SINAD measurements:
RCA performance is still superb and fully transparent:
Dynamic range is exceptional as you would imagine as it is setting the SINAD:
Multitone shows the exceptionally low distortion:
As does 50 Hz response for compatibility with other sites using it:
Jitter could be a hair better given the performance elsewhere:
IMD performance is excellent:
Linearity is perfect:
We have the typical filters but I would stay with default (F3):
The filter selection impacts wideband THD+N measurements so I stayed with the default:
Story is told....
Topping aimed to capture the top spot in the rankings and it got there, besting every other DAC it has produced, albeit with very small margin. If the cost is not a concern and you are buying a new DAC, might as well opt for D90 III.
I am happy to recommend the TOPPING D90 III Sabre.
