Topping D90 Balanced USB DAC Review
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
Absolutely, why in the would we want to have reasonable intelligent discussion...
I don't think talking about training yourself to be immune from bias by ignoring the realities of audible comparison testing qualifies.
The starting premise is absurd. Commonly believed, but absurd.
arnask
Hi all, i've spent many hours reading this threat about D90 and still cant decide which one i should buy: DX7 Pro or D90?
But the most biggest question for me is my usage. Its totally differs from i see you guys usage. I have a big PA system with digital mixer. Sometimes i use it just for conferences, but sometimes for live music (bands of 5 persons). And very often i need to play some music before and after the show. Mostly i use iphone and Audioengine B1 as BT receiver, and sometimes my MacBook directly connected to mixers mini jac->RCA stereo input. And here is the question: do i need a DAC between MacBook and mixer? Will i feel the difference in quality if i will be using one? And if so, then, will i feel difference between DX7 Pro and D90? What is your recommendations?
Tks
Neither seeing as how you have a Macbook. Apple evidently still takes audio serious enough from what we've seen in their $9 phone doggles so rest assured that unless you have some issues with the Macbooks sound output specifically.. There is no reason outside of connectivity options to you what you're asking or aiming for.
Spocko
Southern California
For me the difference is the volume knob - I hate those little buttons on the D90.
Spocko
Southern California
Can this dac be called high end ? I only read good opinions of it
I have a (probably) newbie question, is it posible that usb input performs very well but the others inputs and outputs (spdif, toslink) works really bad?
Sorry for my bad English, i hope u understood me
YES, this DAC both measures as high end and sounds "high end" if you want neutral transparent signal without the DAC adding its own coloration like some tube or R2R DACs. Now you may very well prefer the sound of those colorations, so it's really preference.
tellsapfel
Help needed...
Sometimes while playing the music gets distorted with a loud noise. It happens while the track is playing, not on the start. The music can still be heard in the background. After pausing the track and continue it ist normal again. Used a Mytek Brooklyn before without any problem. Using Roon and SotM SMS 200.
Any idea or similar observations?
thanks
Mikechw
Help needed...
thanks
Does this happen only when you are playing DSD ?
Have you updated the USB driver ?
tellsapfel
No normal CD Quality files. How would i update the driver in the SotM Streamer SMS200? It is not a pc you can install something. The strange thing is, it happes WHILE a track is playing. So for example the track is playing 5 Minutes and then pink noise or something like that.
Update: I upsample in roon to max. pcm rate. Topping support told me that i should only use default sample rate. But doesn´t this look like a bug in the firmware then?
Mikechw
You could try 44.1 x 16 ----> 705.6khz PCM..
I use HQPlayer to upsample from 44.1khz to DSD512.. but I couldn't get 48k x 512 working for D90.
I settled to use 44.1k x 512 (22.5792Mhz) eventually.
Let me try 768khz pcm tonight.. and let you know if its stable.
joltman
I've currently got a FiiO E17 in a FiiO E09K dock. It's powering my HD650 cans. So far, it's been great. Now that I'm working from home full time, I was thinking of upgrading my setup. Obviously, I'm looking at the D90 and thinking of pairing it with the Monoprice AAA THX 887 and making my own XLR cables and my own balanced headphone cable. Should be fun to do.
I've also been subbing to ROON and was playing some SACD rips that are FLAC 88.2KHz/24bit. The FiiO E17 doesn't understand that rate, and ROON upsamples/oversamples to 96KHz/24bit. Reading the Apos site, it says that the DAC supports up to 32bit/768KHz, but does that include 88.2KHz/24bit? I was considering also adding a Raspberry Pi 4 with the Roopiee XL software as a ROON endpoint. Could be fun! Thanks!
elberoth
Warsaw, Poland
My D90 just died. Just stopped playing music, and after switching it off doesn't even want to switch on again.
I was running it it on my desktop computer. It didn't even make it into my hi-man system. Oh well.
bboris77
That sucks. Could it be that the fuse blew for some reason? It should be possible to replace the fuse without opening the unit. I would reach out to Topping support to see what fuse fits in there before shipping it back for replacement/repair.
lazybonesxp
Have the same problem. It happens only with PCM 705/768 khz :-(
elberoth
Warsaw, Poland
It is not the fuse. First is stopped playing music, but the display was still operational. Now it is totally bricked.
Veri
That sucks. Can you work with the seller in terms of warranty? I would hope you'll get sent a new one.
Peib
Spain-Andalusia
Im sad to read that :(
Hope its just an isolated case
