Tidal via Android Auto - with parametric EQ in the car
Music1969
Any of the Fiio devices have USB output and support Android Auto?
I want to use Tidal but apply parametric EQ to Tidal in the car
My car supports Android Auto
Any other devices / softwares ? Tidal essential and PEQ with Tidal is essentials
Want to have separate PEQ for left and right channels
UAPP doesn't allow separate left and right channel PEQ ?
Hello Music1969 :)
I think you cannot use any audio effect with the MQA encoder, you have to use bit perfect.
If you plan to use Tidal without MQA, you can use, for exemple, SpotEQ31:)
EDIT: your post is from 3 months, maybe you had solve your issue?
