Looking for a HDMI output device which supports Parametric EQ
Music1969
Hi looking for a HDMI output device which supports PEQ, independent left and right channels PEQ
Budget under USD500
Any advice?
More details please.
How do you want to get audio into this device?
Do you want it to output regular HDMI, HDMI ARC, or i2s via HDMI?
Regular HDMI - laptop , Apple TV HDMI outputs
Doesn't exist, AFAIK.
Instead of Apple TV->DSP Box->TV, consider Apple TV->TV->DSP Box.
For this, you have multiple options from miniDSP, WiiM, and Raspberries running CamillaDSP.
If you have the skills you might be able to make one with a single board computer that has both HDMI in and out, combined with CamillaDSP or similar. From what I've seen the HDMI input requires specific vendor kernels, and detailed configuration is poorly documented.
Budget under USD500
Any advice?
You can use an HDMI to SPDIF extractor and then everything with an SPDIF input is available to you.
If your notebook has an SPDIF input, you could even use software for EQ/PEQ.
thanks but I actually need HDMI output, specifically for a HDMI input device
It would be much easier to provide all the information, because only then can you get all the possible answers.
How many channels do you need at the end and which HDMI device is at the end?
2 channels, my OP mentions only left and right channels
It is a HDMI-to-Carplay adapter...
miniDSP NanoAVR
this is exactly it - damn need to find one
