Apply Room Eq to Android Bluetooth Sources
conman1040
Sacramento, CA USA
For those who have a good DAC with BT input, but have no way of applying EQ or Room Correction to that input..I may have a solution. I use EQ to get rid of a Room Mode at 81hz. I use Roon to app to apply the EQ, but that limits me to just Tidal as a source. If I wanted to listen to Sound Cloud or SXM over BT, I would lose the EQ. The solution is to apply the EQ  before it leaves the android device. I use an app call Poweramp Equalizer, which is separate from the main Poweramp app. If you follow the instructions in the settings of the app, the app will EQ whatever is playing. You can also dedicate an EQ to a specific BT device. I use it on my android tablet to apply the EQ before reaching my DAC. I am able to listen to hours of Eqd SXM with almost no interuption. Currently it only works on lossy audio and to unlock unlimited playtime (Pro) is $6.
