I'm in communication with Tidal ... also on (Amazon HD 10 - OTG USB - DAC) Topping DX3 pro+ without MQA is same Tidal on Amazon HD 10 - 11 gen is 2.96.0.1144.146 ...I hope that TIDAL did not deceive me, and that they disabled the use of MQA DAC in their application, sending audio data directly to the Android audio path. That is, when MQA-DAC is detected, Tidal deliberately ignores it and uses the Android audio path. Why TIDAL thinks I should pay another $1000 for a NON-MQA DAC for his desire to get revenge on the MQA guys is beyond me.
If they didn't deceive me, then your NON-MQA DAC WILL be used by TIDAL and you will not see the 96 kHz generated by your Android (my phone runs on 48, and the streamer runs on 96). Tidal canceled the use of MQA DAC after version 2.91.1 (probably the v. 2.92 was the first version they castrated. They did a similar joke with LG phones that had built-in MQA support. They did this after v. 2.24, if I'm not mistaken).
I'm on Tidal Hi-FI.
