Thread dedicated to the Topping A50S
H
Human Bass
Ok, good news. Using my smsl m200 (that im trying to sell), the noise is 99,9% gone. Yay.
So I believe the noise is coming from the way the D50S is being powered. I got some fancy ultra low noise 5v psu from Ifi that I hope it will fix the problem.
H
Human Bass
Toku
Japan
Any new A30pro release-production predictions?
Do you have any idea of a possible price?
Looking at the pictures, I'm more concerned about the D30 Pro than the A30 Pro.
The D30 Pro panel shows PCM384kHz DSD256, which is a specification not found in previous Topping products.
Veri
Probably has to do with the choice of cirrus logic DAC chips used. It's still an improvement over original D30 :) (24bit/192kHz DSD 128).
Berwhale
I'm still wating for my A50s :( According to the courier, it managed to fly 6,000 miles from Shenzhen to Heathrow and then get lost, 40 miles from my house. ShenzhenAudio have said they will send a replacement...
antdroid
Reviewer
Seattle
Isn't that just by the push of a button? Shrink down to the size of an atom.
Yea it doesnt look like its a lot of desk space savings, but 2/3 the size of the A90 would be nice. I'll probably hold off on selling my A90 for now.
SnoopKatt
Just got an A50s in. Using a Khadas Tone Board as the DAC, and HD650's for headphones. Incredible sound! No distortion at any reasonable volume level, and super transparent sounding. I don't think I can fault anything about this setup. Huge upgrade from the Schiit Magni 1.
GeorgeWalk
My latest stack Raspberry Pi4 running piCorePlayer, D50s, and A50s. I just got the A50s today. So far I am loving it.
seanca
NFCA is not limited to tpa6120. A50s uses THS6182.
I’m curious, what sparked the idea to use a new NFCA circuit? Does the new circuit actually improve aspects of the old circuit, or was it for another reason? The original A90 seemed flawless already, so I’m curious why change the formula?
JohnYang1997
China
The limited supply voltage and pcb area of A50s and heat dissipation. And A90 and L30 use a full chip of tpa6120 for each channel where half of a chip of ths6182 is used for each channel in A50s.
seanca
Interesting! What about the A30 Pro will that be using the new A50s circuit too? Besides power output, it seems like the A30 Pro might measure even slightly better than the A90?
Veri
I believe A30 Pro will be an SE/cut-down A90 with different power supply than A90, too.
GeorgeWalk
I have question about the D50s/A50s: I am using the volume control on D50s (via remote) and I have the A50s set to max and 0 gain. Should I set the A50s volume knob a bit below max instead? With the Senn 599s the D50s is typically between -40db and -30db
