Technical Review of the NJ&FX AUDIO PW-6 “HiFi Audio Power Switcher” (A/B switch)
pma
Prague
It is all about reliability of relays used only. 5A contacts might not be enough in some cases. And about contacts material - life time, number of operations, possible arc.
KEFCarver
KEFCarver
Tucson, AZ
I respectfully beg to differ in regards to the frequency response- I measured it from 20hz-20khz, and I have tested 2 or 3 different units, all with the same problem. I contacted Douk and they were aware of the problem, but thought it had been solved. Here is a typical frequency response that I measured, in this case the path from AMPA to Speaker 2. I believe that there are transformers used in the VU ckt that are causing this based on the email from Douk.
KEFCarver
KEFCarver
Tucson, AZ
Most of the switching I have down is with power levels that are <50w into 4ohms or <15w/8ohms (depends on which speakers I am using). Probably not much chance of arcing... until the contacts wear out which begs the reliability question. My unit has probably seen 3000 switches I am guessing so far- might be interested to remeasure it at some point to see if there are any measurable changes. Enough for tonight....
solderdude
The Neitherlands
As said, technically utterly impossible for relay contacts to do this. Certainly with speakers. The reason all units seemed to do this is because none of them really did and you are looking at the measurement system and a measurement error showing up consistently.
Relay contacts are flat from DC to well over 1MHz. Period.
When you measure the frequency response using an incorrect load (such as the very high input impedance of the QA) you could see weird things in the response caused by parallel circuits. But .... with speakers this is absolutely impossible.
Relays like the ones used in the device are designed to switch mains or DC voltages and are designed to operate optimally for that.
@pma is correct about the contact material being important and am sure, just like @restorer-john (and me) having to replace similar output relays in older amps that started to make intermittent contact (specifically at lower levels, once it 'arced' by shortly increasing the volume) it would work again till the next time the relay had to make contact.
Your device(s) will very likely work well for many years though so nothing to worry about ... yet.
After many years of usage you may have to replace the relays.
Reactions: pma
KEFCarver
KEFCarver
Tucson, AZ
At a cost of ~$80, I would probably just replace the NJ&FX switcher :) The response I posted was from the Douk device and not related to my QA analyzer and measurement techniques. If you were measuring just a relay you would expect pretty much a "loop thru" response like you get with just the measurement cables/adapters connected. In fact, I was surprised when I got the response I did, and pulled a NOS 12vdc relay out of a parts bin (it was at least 30years old), soldered some connectors onto it, hooked it up to a power supply and measured it- and got would you would expect from having a relay inserted- not much of a difference. If I am able to find the corresponce I had with Douk I will post it. Here is where I uploaded my review of the Douk if you are interested:
lessemm
At the risk of losing your discrete selection functionality, you could try "programming" one of the other buttons -- like B-1 -- to the toggle feature. My guess is it will set B-1 to toggle and remove all functionality from A-1 and A-2, but maybe you'll get lucky and get all three functions.
To "program" I just hold down the target button while pointing at the switch. After a couple seconds the Power light will blink twice indicating the program state has changed.
Another thing that might be annoying for you: Once you do this, the display only shows the selected channel for a few seconds. Then it jumps to show the programmed remote button. For example, in its current state, remote button A-1 toggles my inputs. I hit A-1, the device shows A-B, then after about 3 seconds it shows A-1. Hit A-1 again, it shows A-C for a few seconds, then A-1 again. A bit annoying. At this point, I just turned off the display (remote button B-6) and rely on the LED.
It's a shame this thing is so fiddley with the remote. The default functionality of discrete input buttons and constant input display would work great for my setup.
Mystery solved! Credit to Douk Audio for actually supplying an answer:
The "hold to program" functionality actually has two variants. Holding any button until you get a double flash of the power light puts it into the "toggle" mode. The button you held now toggles inputs.
To get back to "direct select" mode, hold the currently programmed toggle button until you get a single flash of the power light, then let go. The power light will then double flash again, and the device will go back into the original "direct select" mode.
It is extremely sensitive and might take a couple of tries before you get the hang of switching it back and forth.
As far as my Googling can tell, and I'm in IT, so a professional Googler, this is totally undocumented. I haven't asked ChatGPT if it knows about this, but maybe it'll read this forum and figure it out for someone else.
KEFCarver
KEFCarver
Tucson, AZ
Thanks for being persistent and sharing the solution- I will print this out and put it with the device.
sool
Could this switcher be used without attached power? I mean like I set it to either A-B or A-C and it keeps the setting and allows to listen to music in off state even without any power?
Or does it needs to be powered and switched on to pass the sound?
KEFCarver
KEFCarver
Tucson, AZ
It needs to be powered and ON if you want to listen to music from what I remember. I use a usb battery pack to power it, and that can last for several days. If you don't need the remote then I would get a manual switch.
lessemm
Confirmed. It does not pass audio when it is powered off or unplugged.
The TC-7220 should do what you want.
It's still available to purchase from various spots around the Internet. It is unpowered -- purely a mechanical switch with buttons that physically move the contact points.
