Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 5,314
- Likes
- 5,558
Are they any good?
I have never seen objective measurements, but my pair of SB2000s has served me well. In my 13.5' x 13' x 10.5' room, they move enough air with their volume controls set to 25% and AVR levels set to -5dB to deliver substantial visceral impact.
They do have some delay, thanks to their DSP, so some sort of bass management that can delay the mains is nice to have. My AVR finds their distance to be nearly 14' from the MLP, even though they are actually around 7.5' away.
I have recently made a Denon AVR-4700H the brains of my system--even with its middling performance compared to SOTA devices, because I find the bass management and room correction to be worth the trade-offs.
Here is how Audyssey measured and theoretically corrected their performance using 6 measurements around the MLP (my speakers are all crossed at 80 to 90Hz with LFE HP set to the default 120Hz):
And here is a corrected in-room stereo measurement with subs (the Target curve is a 1.0 - 2.0 dB too high in this plot):
So, they do go lower than any budget sub and do it convincingly. I am more than pleased with them. Also, the company is great to work with.
What’s not to like?
The DSP delay, a problem you don't have with Rythmik and Hsu
Fwiw the difference in actual distance for a sub would normally be accounted for by the extra processing time in the sub amp so not unusual not to have matching physical distance set for distance/delay.....
