I see what you mean. Those on the left side are mostly noise. They come from the circuits and are unrelated to the input signal.I always thought so, too.
But then there are so many posts with measurements of harmonics appearing below the fundamental tone.
Perhaps it's only in electronics that harmonics go both ways, which makes sense.
In any case, I always advocate for lower extension because even if you only expect 27.5 Hz (which by the way, the Adam sub has already started rolling off before that so you won't get a really powerful note there) it will play louder and cleaner at that frequency.
Another good thing about the LSR310S is that it has a 200W amp, whereas T10S is at 130W, Sub 8 160W, HS-8S 150W. Using two of them doubles the power. Putting a sub in the corner also yield 9dB room gain thanks to the three surfaces. Really any one of these has enough power for near-field listening.
But I do agree that an excellent sub should have some "tail-room" in its frequency response.
