Hi sometimes I read about people putting acoustic feet or spikes under amplifiers. Or putting the stuff on wooden boards and stuff. Is that really beneficial for sound or is that one big psychological thing? Has anyone cared to measure such things?
Nope. Complete BS.Is that really beneficial for sound
Yep. 100%.is that one big psychological thing?
Usually, people don't want to waste their time to measure claims, especially when these are too good to be true. It would be very easy to measure, tho. Just run the battery of tests of an amp with AP, first with spikes, then without.Has anyone cared to measure such things?
Your amps are six feet tall? Wow.Measurements?
My spikes raise the mains about an inch off the concrete slab.
The "tripod" arrangement allows adjustment of the tilt of the speakers.
I have not measured the audible consequences of having good vs poor alignment. Alignment is just part of the initial setup.
They're six feet tall, so a small difference in the vertical angle can result in a couple of inches misalignment at the top.
Without the spikes the speakers are a bit wobbly on the carpet, and, being over-weighted toward the front, a bit prone to fall on their face when using flexible speaker cables.
They are set to lean forward a little, to put the top and bottom of the panel equidistant to the ear at the listening position.
The rest of the gear is on glass shelves, the glass isolated from the metal rack by little blobs of silicone (?), with each piece of gear resting on its stock feet, some items stack on top of another, and the preamp sits on the Equitech which sits on a pair of bricks for aesthetic reasons, raising the top of the preamp the same level as the tops of the amplifiers, making a dense looking "power block" there.
Oh, one item with no feet sits on a pair of Home Depot Wooden Paint Stirs... ***highly recommended***
Obviously your recommendation of paint stirs indicates your preference for colored sound!Measurements?
Lol true! Especially for yourself to sit on!Spikes no. All you need is a good chair:
http://matrixhifi.com/ENG_contenedor_ppec.htm
Pics? Sounds cool.Measurements?
Easy to test with a DIY 'shaker table' and a hi-tech cell-phone. But the results will be no difference.
