Speaker wires don't carry any energy (power).
audio2design
Yup mostly correct but his 1/C seconds answer is not really right. You would get instant current due to capacitance, probably almost none and the bulb would not turn on but some current would flow. That would take 1 second to actually turn on.
Jim Matthews
Taxachusetts
Derek Muller holds a Ph.D. in physics.
1/c per potential second at all distances - the current doesn't reach 100% that fast (according the the video).
charleski
Manchester UK
The wires contain carriers which allow the movement of charge. That's the crucial point. Note that charge is a property of electrons (and protons), but movement of charge is not the same thing as movement of the particles carrying it (he spent a large part of the video making this exact point). A moving charge creates an electro-magnetic field, and that is what conveys the energy, as stated in the video (though this analysis is all based on classical mechanics, but all I know about quantum electrodynamics is that it's a lot more complex). The more energy you want to move, the more charge needs to move to support the required field, and so you need to have more carriers available to facilitate that movement. The easiest way to achieve that is to use a wire with a larger cross-sectional radius (i.e. fatter).
audio2design
Cut the wire half way what happens? The only current that flows is capacitive and inductive. It's not a propagated field in the wire, it's a propogated field from the wires close to each other and the rapidly changing field. I suspect current pulse initially (small) drooping as C/L it propagates then finally turning on one the field fully propogated.
Electrons don't carry the power but they do induce the magnetic field.
It's really easy to test though. 50 or a 100 feet of wire would be more than enough. No need for long wire.
tomtoo
Germany
But its not the field that exists between the source and the light bulp that delivers the energy to the bulp. Its the field around the wires that follows the wires. I dont think that 1/c assumption is correct. Iam not a physicist so if iam wrong i dont loose my reputation :). So the bulp could see the field of the source in 1/c but it would not power it. We would need only tiny wires if this would be different. No current needet would be cool.
tomtoo
Germany
Lets see it different, lets have two bulps in serial. One on the moon and one on the earth 1m near the source. That on the earth would see the signal first, that on the moon later. So that on the moon would light later. But that on earth can not light, as long that on moon does not light couse the current has to go trough both. So the light on earth would shine in 2 seconds, even the distance between source and the bulp on earth is only 1/c.
Step two:
Replace that bulp on the moon just with the cable resistance?
Something must be seriously wrong with that 1/c.
Qbd
The 1/c answer certainly feels wrong, that’s for sure.
Could a dude with a wire cutter at the bend 1/2 light second away not send information instantaneously by cutting the wire?
That is, what happens if the wire is cut just before the switch is flipped? The bulb must act exactly as if the wire was not cut for at least 0.5 s, or else we have just transfered information faster than the speed of light.
tomtoo
Germany
Something stinks. I dont know what exactly but it stinks. ;)
charleski
Manchester UK
The energy is being transmitted by photons, which is where the 1/c comes from. If you want an alternate visualisation of what's happening you could take a look at this:
tomtoo
Germany
The 1/c comes from the distance source to bulp in that example from veritasium. It would be better saying distance(source-load)/c. And this would say it does not matter how long cables are, couse only the distance(source-load) matters. You could span cables trough the universe, or 10cm long, same time as long distance source load not changes. And i say that stinks.
Qbd
Reading a bit of the youtube comments (always a dicey proposition), is perhaps the gist that:
* The light bulb will theoretically switch on at 1/c s, but since the energy amount is so low, it won’t actually turn on.
* The light bulb will actually, i.e. visibly, turn on after about 1 s.
* The light bulb would turn on (after 1/c s) just as much as it would if the wires were cut at the 1/2 ls bends.
Which leaves this feeling like a big nothing-burger? I mean, it’s just saying that a miniscule amount of energy can be transfered between two parallel wires?
sarumbear
Really? Mostly correct!!! :eek: The world is also flat...
Why do people need to comment on things that they have no idea what-so-ever?
tomtoo
Germany
Why are you so arrogant to forbit other people to communicate? Why not come first up with your idears?
Lambda
My First tout was is he considering transmission line impedance and what is the impedance.
in this case the cable don’t even have to be connected at the ends for light to become on instantly.
You can also consider it a 2 dipole antennas close together
tomtoo
Germany
Yes if you not look at the current. If you see the light bulp as a receiver this would be understutable for me. But it needs current?
