Momomo67890
- Joined
- Mar 2, 2023
- Messages
- 32
- Likes
- 17
Old recevers off face book $25-50 strip it down easy.
Yes, I had really good experiences with them too but couldn't remember them on earlier post.there is also Front Panel Express.
I love it, very nice jobMy MiniDSP 4x10 digital preamp with 2x analog input and phono stage from 15 years ago. Made out of an old Aiwa CD player chassis, burled maple front and one of my old copper etchings for a back plate. All kinds of possibilities to suit your tastes and whimsy if you've got some tools, vision and skill.
View attachment 305024 View attachment 305025
I do like the look of the wood case. Did you build it around metal you had with the vents? The hardest part I run into is finding things with vents so I can have some airflow.and sometimes I use wood a 1/8 aluminum sheets scraps, but that require some DIY.
Nice!!, that's the spirit! I still try to make the bottom of aluminum for grounding.That is great! I thought the entire top was metal. I do like woodworking. I built a tube amp in an old 3 bottle wine box. I treated the wood with fireproofing spray and on the test pieces MAP Gas could char the wood but it did not catch fire.
well you have the heatsinks and the power supply, the rest will come up easily, you could make a small box with acrylic panels, angular aluminum and some screws, a good thing of acrylic is that you can sand it an paint it you want, that can be very inexpensive and I'm pretty sure that whatever country you live you can get the parts on a construction store. and hack saw, a drill and spray paint is all what you need.Rod Elliott P101
