Software for 3-way active XO
I have a music PC running Windows 11. On it, I have Roon and Dirac.
Roon sends the signal to a virtual soundcard that Dirac created, and Dirac sends the signal to my Holo Audio May DAC connected to a USB port.
I would like XO DSP software to sit between Dirac and the USB port. I know I need a 6-channel DAC, something like the Okta8 Pro.
Can I use Audiolense or CamillaDSP, and how would it be set up?
You should be able to apply Camilla to the Dirac Virtual Audio Device, split your left/right channels into 3 output channels each using a mixer, then individually EQ the resulting channels. I haven’t done this before, just guessing based on documentation.
