I need to get a balanced, over the ear headphone for amplifier testing that is popular much like my Sennheiser HD-650s. Is there such a product?
Something I always point out when folks are talking about HD650-esque replacement cables: the excellent 3m OEM cable is $11, from Sennheiser. I couldn't make a cable for that cheap if I wanted to; hell, a good 4-pin XLR connector is going to cost as much as that.
It's become common practice to use balanced connectors on anything and everything now. If a stock cable is detachable and has 4 conductors then someone will sell a balanced version. If not, there will be dealers who manage to get away with selling re-terminated and re-cabled versions.
Like @maxxevv said, just get and extra cable for the headphones you have, re-terminate it to something with 4 poles, and then make some adapters from there.
My HD6XX came with the shorter 3.5mm plugged cables. And I bought an aftermarket 4-core one, terminated in 2.5mm TRRS.
The OEM cable that came with the HD6XX was surprisingly poor when I measured the resistance of the cable versus the aftermarket one. It had effectively double the resistance value of the replacement cable. ( measured from plug R+ , L+ to headphone connector pins R+ and L+ and averaged.)
The original Sennheiser cable that came with the HD650 may be different, so it might be worth a check if have a chance to do such a comparison.
Gosh, I paid $23 for a third-party version. Had no idea the authentic one is so cheap!Something I always point out when folks are talking about HD650-esque replacement cables: the excellent 3m OEM cable is $11, from Sennheiser. I couldn't make a cable for that cheap if I wanted to; hell, a good 4-pin XLR connector is going to cost as much as that.
Though, the option to make your own balanced cable using the OEM cable as a base sounds interesting, if it truly comes with 4-cores.
The OEM cable is 4 cores, BUT it's litz wire.
