Veri
- Joined
- Feb 6, 2018
- Messages
- 9,599
- Likes
- 12,041
LolLet us know if there is goose pumps
I own a 789 and HE6se and I can say that even at maximum output on the 789 with my DAC at +19dBu (6.9v) there is no clipping. The 789 can deliver 3800mAh into 50ohm which is far less than the 6W max and just below the 4W recommended by HifiMan.
I'd personally leave the SU-8 at maximum output and and use gain 2 on the 789 (unity gain). It's more than you'll need and both using high gain and lowering the output of the SU-8 lower performance.
E: Fun fact, the 789 can make my HE6se jump on the table from the excessive vibrations it produces at high volume. Planar drivers can take silly amounts of power, I've always wanted to see like a LCD-MX4 at 15W (literally like 140dB theoretically).
I assume its because of digital volume control in su-8, lowering output means lowering effective bit depth.Why would lowering the output of the SU-8 affect performance?
However, ESS chips use the full 32-bit depth for volume control and should not matter much to affect actual resolution on the DACs output other the voltage level.
There is no such thing as lossless digital volume control, and ESS' implementation is no exception.Volume control in SU-8 is lossless.
The DNR is specified for full volume, and any dB of attenuation (be it done inside the DAC or at the source) reduces the DNR by that much as the noise floor remains the same.
Does the USB input stay active even when selecting another input, or does it deactivate when you've selected another input?
I picked up a SU-8 V2 from Shenzhen Audio last week and from what I can tell, the USB input is only active if it's the selected source. Otherwise, with Windows 10 at least, the USB audio device (and another bit I don't have a driver for yet but I'm using optical anyway) disappear.
Just a heads up, I got my v2 from Massdrop last week and mine exhibits the same power supply audible noise mentioned in the original SU-8 thread here: https://www.audiosciencereview.com/...nts-of-smsl-su-8-dac.3778/page-10#post-116372
The noise also goes away on my v2 after a "warm reboot". I noticed it changed in pitch when the display was turned on/off, so I would definitely guess it's power supply related. It does not seem to have any impact on sound quality though.
If you are able to find the part making the noise (probably an inductor), potting it using hot glue or epoxy (better) usually can fix the problem, although it's just an annoyance which is common with many switching power supplies.
What about switching to SE HD800 cable to keep everything in the analog domain?
Crosstalk might actually be beneficial for headphone use...
Indeed. A carefully constructed crossfeed is not the same as unintended crosstalk seeping through the signal..This is a mistaken view that gained currency because of the old Headroom amps. If you hear the imaging through headphones of BACCH-HP processing, which does not add crosstalk, you'll realize that crosstalk is not good for headphone listening.
