SMSL SU-1 Stereo DAC Review
Rate this DAC:
    Votes: 8 1.8%
    Votes: 9 2.0%
    Votes: 56 12.3%
    Votes: 381 83.9%
pseudoid
What's the difference between a DAC designed for active speakers and a DAC designed for passive speakers? Or maybe I don't understand your post?
I get your rhetorical (but trick) question: The cheapest way I can figure out how to connect a DAC to passive speakers is thru F.M.!;)
Although that would be unnecessary in the case of active speakers.​
norcalscott
Sierra Foothills
Just saw this little DAC opened and it’s a really nice build ruined by the Lelon caps they used. I thought these guys use top tier parts.
Lelon are largely considered mid-range, and should be sufficient at this price level. Are you implying that this DAC would perform better if they had used "top-tier" caps?
jomo
They make little or no difference to the sound when they are working properly. It's about reliability. Having just replaced 4 bloated Lelon caps in my sub amp, I would rather spend the added $1 and get a higher tier caps.
Tom's hardware says fourth-tier for Lelon. I know EEVBlog thinks Lelon is bad, and cries about it when he sees them. Restorer-john, an electronics repairman that is all over ASR thinks they are poor as well. Granted, this DAC is probably the easiest service for any cap there is, but you don't see other quality, low cost DACs resorting to fourth-tier level.
TonyJZX
z tier caps for $80 is about what i would expect really...
JSmith
Algol Perseus
low cost DACs
Well it is $80... but fair point to an extent. Often it can come down to design though, rather than brand of capacitors used (see below) and in a DAC they're not stressed heat wise really.
JSmith
TonyJZX
i get the animosity because if you're actively involved in removing their leaky caps then youre reluctant to buy new products with them
BUT i mean... there's two caps in there... with minimal stresses unlike a PC PSU
i would imagine we will never see bulged or leaking caps on this or any other SMSL dac... or wait 5yrs plus
on an $80 unit i mean chance it...
JktHifi
What HiFi recently published an article arguing for simple DAC designs. The example they gave was a $15,000 model from TAD.
I'd love to see it measured against this $80 SMSL.
It’s not just DAC but also DDC. Probably it does something to the newly created digital out.
JktHifi
That is a product for, forgive me, people with more money than common sense. Just ridiculous to think there is any reason to purchase such an expensive DAC.
Or, probably the SMSL is too cheap?
Joffy1780
Tell that to the makers of the Wiim “Pro”.
Which is a streamer, not a standalone DAC.
If SMSL can add the functionality of the Wiim Pro to a DAC with this performance for an extra $70 then you can criticise the Wiim for not outperforming a standalone DAC.
norcalscott
Sierra Foothills
I'll agree about reliability, but in this use case, at this price, I suspect these caps will last through the usable life expectancy (sadly, we live in a disposable world). I suspect that in order to meet the price point, SMSL had to cut costs in ways that would not impact performance.
As an aside, I know that there have been reliability issues with Chinese caps in the past (defective materials, etc) but one thing that these manufacturers get really good at over time is improving reliability without increasing cost. I wouldn't use this brand in a premium product, but it is probably a fair tradeoff to keep costs down without affecting performance for low cost components.
Ecaroh
The +5V wire isn't present from the factory, so no no need to mod.
Many thanks for this. Are you finding a diagram somewhere for that AliExpress splitter? And are all the connectors male? The USB A is, can't tell about the input-side USB C.
staticV3
They're all male:
Intended use case is Android phone+ Power bank -> Type-C DAC.
However, there's nothing preventing you from using it with the SU-1 on Windows instead.
SuicideSquid
No but you don't understand. It adds more depth and a holographic quality to the soundstage and if you think your $150 DAC is sufficient you just don't know anything about audio and obviously have tin ears.
/s
pseudoid
/s
I'm giving you a Like only because I think you forgot a Smilie at the end.:)
