it's not even the size of a penny... puny knob..did they make the knob smaller than the C200? or is it an optical illusion. Big unit requires big knob!
does it still always show sampling rate rather than volume even if you have headphone plugged in? Another dumb design decision. I only need to see the spl rate briefly when it changes. (My player tells me what spl rate it is sending anyway.) Rest of the time I want to know the volume level.
will try with headphones later.. I don't know if it switches to volume. It certainly doesn't while music is playing via speakers.
Don't stick the multimeter probes into the sockets, you may short the outputs.
Instead, use DIY plugs like these:
View attachment 361339 View attachment 361340
Or use male->male extension cables and probe the other end.
For the 1/4" output, make sure you use TRS, not TS, as that would again short the output.
Edit: also, for matching output volumes, you may want to use an adapter like this to probe the output voltage with your headphone plugged into the Amp: https://www.aliexpress.com/item/3256803497862592.html
Reason being that your tube Amp may have substantial output impedance, which will give you incorrect results when you try to match the output with just the multimeter as load.
For example, you may match the unloaded output voltage at 1.0V for both Amps, but when you plug in your headphones, the DL200 will stay at 1.0V while the Tube Amp may drop to 0.xV due to the high output impedance.
By measuring and matching the output voltage with the headphone already inserted into the Amp, you account for any potential voltage drop.
Cheers!
I actually have a male - male 3,5mm cable that I can use for this.
And yes, those are TRS cables. (I don't want to compare the TRS to RCA, if that's what you mean. I just want to see if the tube amp sounds noticeably different to the built-in amp of the SMSL. If not, I might actually sell it.)
Can I measure the output impedance with the multimeter? Will it matter much with the 300 Ohms of the Beyer DT1990 Pro?
