staticV3
- Joined
- Aug 29, 2019
- Messages
- 15,877
- Likes
- 28,376
The DL200 can drive the DT880 600Ω to ~110dB SPL Peak.Will this power Beyerdynamic DT 880 - 600 ohm?
That's about 8x my usual listening volume.
I have a Mac m1 running Sonoma. With a C200, there's nothing special needed to output beyond 96hz.. Device automatically recognized. The DL200 looks to be almost identical in function.Is there a driver needed for USB 2.0 on a Mac? To output beyond 96KHz? Sounds weird, maybe it's badly translated.
No. It works up to 768 kHz and 32 bits.Is there a driver needed for USB 2.0 on a Mac? To output beyond 96KHz? Sounds weird, maybe it's badly translated.
What is the benefit of using the optical out vs usb? Aren't they both just passing the digital signal to the dac?So far, it sounds to me as if the majority of issues people seem to have with SMSL (and Topping, etc.) products all lead back to these people relying on USB...
USB is the bane of any music lover. Why would you even resort to using it?!
I'm using the optical output and it works absolutely flawlessly.
That said, just like any DAC I've used so far, the DL200 does "pause" briefly when playing random lists on Tidal where the sampling rate changes. Which is truly a bit annoying. I suppose, that's the bane with modern hi-res streaming options where you get different "formats" all thrown in together, and there's really no way for the DAC to handle it without any issue.
USB has a bigger bandwidth and allows everything up to 768kHz (and more...) while optical is limited to 96kHz (IIRC) but has the advantage of offering galvanic isolation, and hence rejecting every form of electrical noise that could leak in from the source device.What is the benefit of using the optical out vs usb? Aren't they both just passing the digital signal to the dac?
You can think about optics if you need almost zero delays, much less than usb, where the delays are about several ms. Galvanic isolation does not matter for DL200. Optical cables are also insensitive to interference. But this also does not provide any advantages in the case of DL200. However, optical cables can be made very long without any problems.What is the benefit of using the optical out vs usb? Aren't they both just passing the digital signal to the dac?
All Differential->Single Ended adapters (4.4->3.5, 2.5->3.5, 4pin XLR->6.35, etc.) are dangerous and can potentially destroy the Headphone Amp they're connected to.Can anyone recommend a headphone cable or adapter that converts my 3.5mm connections to 4.4mm that is safe for this DAC?
the advantage is incredibly simple:What is the benefit of using the optical out vs usb? Aren't they both just passing the digital signal to the dac?
There is no reason for you to do this. DL200 does not have a balanced HPA. 6.3 and 4.4 mm output the same signal. It's easier to connect to 6.3 with a standard adapter. The balanced signal is present only on the TRS outputs.Can anyone recommend a headphone cable or adapter that converts my 3.5mm connections to 4.4mm that is safe for this DAC?
Good to know. I'm using USB currently with zero issues. I have no optical cables available but may order some if I start experiencing problems.the advantage is incredibly simple:
you don't need any USB drivers..
USB is such a fucked-up connection that I refuse to use it whenever there are alternatives.
Optical allows me to connect my Motherboard to the DL200 without ANY issues whatsoever. No driver needed, no connection issues, nothing.
Everyone who has reported issues with SMSL devices has been using a USB connection. It's very apparent that it's simply the WRONG way to connect these devices.
that's very fancy, I suppose.. Although, optical does 24bit/192kHz max
Of course, it doesn't matter at all, since nobody can hear anything beyond 44kHz sampling rate anyways..
Are you sure? The website states otherwise.There is no reason for you to do this. DL200 does not have a balanced HPA. 6.3 and 4.4 mm output the same signal. It's easier to connect to 6.3 with a standard adapter. The balanced signal is present only on the TRS outputs.
Currently using Fidelio X1's with a fixed (detachable) 3.5mm connection. Would this adapter work for my current cable or is there a better option?All Differential->Single Ended adapters (4.4->3.5, 2.5->3.5, 4pin XLR->6.35, etc.) are dangerous and can potentially destroy the Headphone Amp they're connected to.
If you have headphones with a fixed 3.5mm or 6.35mm connection, then please just use the DL200's 6.35mm output.
You can safely convert 6.35 to 3.5mm and vice versa.
audio46.com
Absolutely. Only through the tip and the second ring of 4.4 jack does the signal pass through, the other two rings are simply grounded.Are you sure? The website states otherwise.
Ok. That's confusing since the website states "4.4mm balanced headphone jack on the front panel".Absolutely. Only through the tip and the second ring of 4.4 jack does the signal pass through, the other two rings are simply grounded.
