FreakyKiwi
- Joined
- Jun 29, 2023
- Messages
- 204
- Likes
- 164
What mode is your DL300 set to? Both DACs use the XMOS XU-316 so I would have expected the same behaviour.Switching between USB 1.1 and 2.0 ALSO worked.
The C->C incompatibility is caused by missing pull-up/down resistors on the USB jack AFAIK, so nothing to do with the USB chipset or firmware.What mode is your DL300 set to? Both DACs use the XMOS XU-316 so I would have expected the same behaviour.
It doesn’t look like the DL300 has a USB mode menu option (Using the dial on the unit to explore the menu. Not the remote)What mode is your DL300 set to? Both DACs use the XMOS XU-316 so I would have expected the same behaviour.
My DL200 works fine from my Android phone (Poco F2 pro) with a cheap C-C cable in USB2 (or 1) mode.The C->C incompatibility is caused by missing pull-up/down resistors on the USB jack AFAIK, so nothing to do with the USB chipset or firmware.
To be fair, the DL300 connects on the first try with my android. With the DL200, most of the time I have repeat the process to get a connection (plugging in/out of the device). So I think this problem is specific to the DL200 (or maybe just my unit). On the Apple, it works on either 1.1 or 2.0, but I have to switch between the modes to get a connection.No, there's more to it I think. My DL200 works fine from my Android phone (Poco F2 pro) with a cheap C-C cable in USB2 (or 1) mode. I blame Apple.
Damn, I was looking for another reason to hate Apple.To be fair, the DL300 connects on the first try with my android. With the DL200, most of the time I have repeat the process to get a connection (plugging in/out of the device). So I think this problem is specific to the DL200 (or maybe just my unit). On the Apple, it works on either 1.1 or 2.0, but I have to switch between the modes to get a connection.
I must also note, that this connection behavior (with my Android) on the DL200 occurs ONLY after a disconnect and attempted reconnect. Not on 1st connection after the DL200 is turned on. The 1st connection always works.Damn, I was looking for another reason to hate Apple.
Anyway, I have no issues with the USB connection to my DL200 so we should probably blame SMSL quality control here.
That's weird, I assumed they would both have the same USB features.It doesn’t look like the DL300 has a USB mode menu option (Using the dial on the unit to explore the menu. Not the remote)
Volume Control on the D-6s measured at 1kHz and Full-Scale sinewave on XLR outputs
SN: 33212330199
Edit: I have double-checked several times, the "missing step" is real and it fortunately applies to both channels - nothing to worry about though.
I got mine today and rudimentarily measured the steps in the volume control using headphones, a 1 kHz tone and an SPL meter app on my phone.
The ESS chip can go from 0 dB to -127.5 dB in 0.5 dB steps for each channel (ES9039Q2M datasheet, page 15). The DL200's volume control has only 100 steps from 0 to 99, however. Thus, it may well differ in some way.
Volume 00 is mute. From 99 down to 25 is in 0.5 dB steps, i.e. 25 is -37.0 dB, 50 is -24.5 dB and 75 is -12.0 dB. 20 is 5 dB lower than 25, i.e. 20 is -42.0 dB. Below 20 is unclear but 01 is about 28 dB below 20, i.e. 01 is about -70 dB.
The line output is closest to 2 V RMS RCA and 4 V RMS TRS at volume 95, i.e. -2.0 dB, giving 1.9858 V RMS and 3.9716 V RMS, respectively.
Maybe @SMSL-Mandy can give the exact values.
I don't use BT on mine but just did a quick test using my very sensitive AKG K361 headphones and couldn't hear any noise.static noise using BT.
I can hear during pause or no sound, an electrostatic base of background noise.
My phone was connected using LDAC if that makes any difference to the problem.
I have heard other noises from the DL200, especially when using high gain, so i can well believe you.
Your iems are quite sensitive and not demanding on power, are you running at low gain?
I do think a USB-C dongle would be a better solution for you, I'm not a fan of BT though.
The es9039q2m outputs significant UHF content, but its frequencies are too high to be heard. In addition, some chaotic pulses are visible at the output of the DL200. I think under the right conditions they can be heard, maybe like the sound of a needle rustling on vinyl. I won't say for sure.Hi everyone, I tried to search the previous 41 pages, but I couldn't find a reference to my problem: static noise using BT.
Basically I use the DL200 exclusively as a Bluetooth receiver (bedside), paired with my smartphone at approximately 1 meter range. And when I listen to music or play games with my P1 Max IEM connected 4.4mm, I can hear during pause or no sound, an electrostatic base of background noise. It's not loud and is obviously covered as soon as the sound starts again... but it's present. I also tried with the smartphone in airplane mode, leaving only BT active, but it didn't change much...
Is there anyone else having the same problem or is this a defect in my unit? Should I do some testing? In fact, I haven't yet tried to see if I can leave the phone at a distance greater than 1 meter or try other headphones.
Many thanks for any suggestion.
So, they are the same as SMSL D-6s, tested by Amir here ?SMSL are joking. They didn't guess any of the digital filters. On my DAC I got the following list (ESS filter number in brackets):
FL1 (08) Minimum phase slow roll-off low dispertion
FL2 (01) Minimum Phase
FL3 (02) Linear phase apodizing fast roll-off
FL4 (03) Linear phase fast roll-off
FL5 (04) Linear phase fast roll-off low-ripple
FL6 (05) Linear phase slow roll-off
FL7 (06) Minimum phase fast roll-off
www.audiosciencereview.com
I can't tell FL2 from FL7, but everything seems to be the same.So, they are the same as SMSL D-6s, tested by Amir here ?
SMSL D-6s Balanced DAC Review
This is a review and detailed measurements of the SMSL D-6s balanced stereo DAC with Bluetooth support. It was sent to me by the company and costs US $199. I was pleasantly surprised with the new industrial design which while minimalistic, manages to impress with its modern style. Love the matt...www.audiosciencereview.com
I'm into 2.1 channel + speakers and have been using MiniDSP Flex for 3 months happily.My impressions after a couple of weeks of use...
I would probably keep it, but I decided I needed a multi-channel DSP, I will get that from minidsp, so DL200 is very good, just is not a perfect fit for me.
