A little update on my attempts at adding additional EMI shielding to the switching PSU.
There is no sonic benefit at all, it appears that the device is designed well enough that additional shielding is not strictly necessary. I will apply copper tape to the top and a layer of the 0.1mm tape over the copper tape. And I will remove the shielding material I applied to the PSU as I don't think it made any sonic difference or any additional noise protection from entering or escaping from the PSU. Which is quite remarkable considering the cost of the PSU. I will try and post pics after I down size the pictures I took of the shielding that I applied. I was expecting more, as I have used this material on my tube amplifiers with excellent results, and on and around speaker terminals on the inside of various enclosures I've built in the past. On speaker cables, and internally for passive crossovers, capacitors especially it has always made an improvement. I think that the switching frequency maybe possibly high enough that the PSU isn't a noise maker. YET another reason why it proves it's superiority over the DA-8s with the external brick power supply. I did for a brief moment use the DA8s to confirm that the sound of the DA-9 was indeed perceivably much better before I applied the tape, thereby making the comparison fair. I can't wait for someone, anyone really to do an independent, non-funded/sponsored evaluation of the DA-9 amplifier. I truly believe that bang for the buck wise, it hits well above its weight class. Add cost into that and well, the big names have some real competition that they will lose unless they update their mentality about well engineered Chinese made goods. It's very similar to watching the early days of Japanese technological advancements including in the automotive sector. They seem to be taking what works, improving it every generation and learning at an alarming rate. The future looks bright and the segment will no longer be considered "budget, or entry level". Watch out name brands. They're coming for you if they haven't already arrived!
Pictures will be posted when I get to it. I'm in no rush to re-open the amplifier for a 4th time!
